[gdal-dev] A CSW query that seems to me works badly
Even Rouault even.rouault at spatialys.com
Wed Nov 16 04:03:20 PST 2022
> But I didn't imagine that write this
> ogrinfo --debug on -ro -al "CSW:http://geodati.gov.it/RNDT/csw" -where
> "abstract LIKE 'Impianti e strutture ricettive'"
> was a search in OR: Impianti OR e OR strutture OR ricettive, because
> since it's some kind of SQL command, to me it meant exactly the whole
> string  `Impianti e strutture ricettive`.
Yes, it should.
> But I understand that this is not an error, and that command expects
> that type of OR search, unless you put everything in double quotes. Am
> I right?
I'd assume this is a server-specific behavior/bug. But maybe this is a
documented behavior of CSW, which would be odd to me (since the OR
behaviour can be cleanly modeled with OGC filters). But I'm not a
specialist of CSW, so I let you read the spec :-)
Even
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221116/867c91da/attachment.htm>
