[gdal-dev] Motion: adopt RFC 87: Signed int8 data type for raster
Kurt Schwehr schwehr at gmail.com
Wed Nov 16 11:41:44 PST 2022
Hermann,
Speaking to GDAL being one (not very small) piece of an ecosystem of
libraries and tools:
This is exactly what unit tests are for.  A well done tool or library
should have the tests that cover their critical uses of libraries they
depend on.  It's often referred to as the "Beyonce rule": "If you liked it,
you should have put a test on it." (c.f. here
<https://www.oreilly.com/library/view/software-engineering-at/9781492082781/ch01.html>
Now is a great time to make sure that your workflow has a check for proper
handling of 8-bit rasters.
-kurt
On Wed, Nov 16, 2022 at 11:39 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> I think long term compatibility is a very desirable feature, and several
> applications just use GDAL as part of their code base without even being
> aware of what is happening in the GDAL development front. The same is true
> for several other libraries, given the fact the use of package managers
> (VCPKG, conan etc) are becoming more common. For some code bases, GDAL is
> just a small cog, and I believe it is very easy for the developers to
> simply download the next version from the package manager thinking that
> they are getting mostly bug fixes and not being aware of new silent
> incompatibilities.
> We try to avoid breakage or silent breakage when reasonable, but sometimes
> it is the best thing to do. People/software who depends on the past
> functionality will see the tests related to their code testing
> GetMetadataItem("PIXELTYPE", "IMAGE_STRUCTURE") == "SIGNEDBYTE" break and
> will probably figure out they should read GDAL release notes to understand
> what happens. It is not the first time nor the last one we will do that.
> Sorry, but I think it is funny that you mention removing GDT_Byte would
> have breaking implications, since I am expressing my reservations against a
> change that will have breaking implications. :)
> My perception is that > 90% of current uses of GDT_Byte are for the
> unsigned usage. Of course their might be some domains where this is not the
> case.
> I don't understand what limitations you are referring to. Perhaps the
> support was broken to some types of raster files?
> This is described in the RFC: " the absence of a proper data type means
> that it is easy to forget to test the PIXELTYPE=SIGNEDBYTE metadata item in
> all places where the value of pixels is taken into account. There were
> special cases for statistics computations, but most of the other code, such
> as the overview or warping computation code had no provision for it, and
> consequently mis-interpreted negative values in the range [-128,-1] as
> positive values in the range [128,255]." . So current support of signed
> 8-byte within GDAL was broken in a number of places, and the new GDT_Int8
> data type enables to fix it. One could argue that the past behavior of
> reporting a metadata item that altered the semantics of GDT_Byte was a
> silent breakage of the API promise of GDT_Byte being unsigned.
> In my field, signed 8-bit images representing categorical images are very
> common, given the fact they can be used fully decompressed and represent a
> null value/nodata in very convenient way (as a negative value).
> You should have a better experience with GDAL 3.7 then, pending perhaps a
> few changes in your code.
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221116/a39a4a5c/attachment.htm>
