[gdal-dev] A CSW query that seems to me works badly
andy aborruso at gmail.com
Fri Nov 18 04:18:25 PST 2022
Hi Even,
On Fri, 18 Nov 2022 at 13:01, Even Rouault <even.rouault at spatialys.com>
wrote:
> This is mostly an implementation detail that should have no consequences.
> If you really want to change that, I'd suggest you to submit a pull request
> with the change directly.
since it is not possible to query using the title field, and since I can't
use double quotes for literals query, for me it was very useful to have the
debug XML query output.
Starting from it, I can use curl and run something like
curl -s -k -X POST -H "Content-Type: application/xml; charset=UTF-8" -d
'<?xml version="1.0" encoding="UTF-8"?><csw:GetRecords resultType="results"
service="CSW" version="2.0.2" startPosition="1" maxRecords="500" xmlns:csw="
http://www.opengis.net/cat/csw/2.0.2" xmlns:gml="http://www.opengis.net/gml"
xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="
http://purl.org/dc/terms/" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"><csw:Query
typeNames="csw:Record"><csw:ElementSetName>full</csw:ElementSetName><csw:Constraint
version="1.1.0"><ogc:Filter><ogc:PropertyIsLike wildCard="*" singleChar="_"
escapeChar="!"><ogc:PropertyName>dc:subject</ogc:PropertyName><ogc:Literal>salute</ogc:Literal></ogc:PropertyIsLike></ogc:Filter></csw:Constraint></csw:Query></csw:GetRecords>'
https://geodati.gov.it/RNDT/csw
But to write this command, I can't copy and paste from ogr output, I have
to remember first to standardize the use of quotes.
I will try a PR.
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221118/4b901638/attachment-0001.htm>
