[gdal-dev] Working with IFC files
Jean-Roc Morreale (ml) jrmorreale_ml at enoreth.net
Fri Nov 18 09:13:14 PST 2022
In this study, after talking with Even, the full support of IFC was
deemed to exceed the functionalities of GDAL but the transformation of
a limited subset to the Simple Feature model could be supported (such
as the outer hull of a building, the shape of the floor, etc.).
We did not pursue this track as we wanted a full support in QGIS (which
isn't straightforward either).
Le mercredi 16 novembre 2022 à 11:22 +0100, Jean-Roc Morreale (ml) a
écrit :
> Hi, we sponsored a feasability study for ifc support in qgis/gdal in
> 2021, it is in in french but I'll try to sum it up asap
> Le mercredi 16 novembre 2022 à 10:00 +0100, Stefano Iacovella a
> écrit :
> > Hi all,
> > I am working with BIM data to integrate them in a geodatabase.
> > Data are delivered in IFC format (1)
> > I am curious about the possibility to ingest them using OGR.
> > As far as I know there's no driver available.
> > Is there someone in the list who has had some experience in a
> > similar
> > scenario?
> > Thank you
> > Stefano
> > 1) https://standards.buildingsmart.org/IFC/DEV/IFC4_2/FINAL/HTML/
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
