[gdal-dev] jp2openjpeg: gdal build not finding openjpeg
Ashley Mort ashley_c_mort at raytheon.com
Fri Nov 18 15:16:33 PST 2022
I am trying to get jp2openjpeg in my GDAL build.  This is in a docker image running CentOS7.  I have successfully installed other libraries with GDAL (PROJ, Expat, LibTIFF, etc.) so I'm not sure why it's not finding OpenJPEG.
Can anyone provide any advice on how to get the jp2openjpeg driver going for my GDAL build?  My Linux & GDAL build knowledge is mediocre at best.  I am willing to change GDAL version or try to use it as a plugin if necessary but I'm just not sure what I need to be investigating.  Any ideas?
Thanks!
Ashley
/usr/local/lib has:
-rw-r--r--. 1 root root    564662 Nov 18 18:59 libopenjp2.a
lrwxrwxrwx. 1 root root        15 Nov 18 18:59 libopenjp2.so -> libopenjp2.so.7
-rwxr-xr-x. 1 root root    458888 Nov 18 18:59 libopenjp2.so.2.5.0
lrwxrwxrwx. 1 root root        19 Nov 18 18:59 libopenjp2.so.7 -> libopenjp2.so.2.5.0
GDAL ./configure output shows:
checking for OPENJPEG... no
OpenJPEG support:          no
Dockerfile parts:
#install OpenJPEG (GDAL JP2OpenJPEG jpeg2000 support for reading JPEG2000 compressed NITF files)
ADD https://dev-server:8443/openjpeg/openjpeg-2.5.0.tar.gz /
RUN tar xzf openjpeg-2.5.0.tar.gz && \
    rm openjpeg-2.5.0.tar.gz && \
    cd openjpeg-2.5.0 && \
    cmake -DCMAKE_BUILD_TYPE=Release && \
   make -j6 && \
    make -j6 install
ENV LD_LIBRARY_PATH=/usr/local/lib:/usr/local/lib64
#install GDAL
ADD https://dev-server:8443/artifactory/com/gdal/gdal/3.4.1/gdal-3.4.1.tar.gz /
RUN tar xzf gdal-3.4.1.tar.gz && \
    rm gdal-3.4.1.tar.gz && \
    cd gdal-3.4.1 && \
    ./configure --with-openjpeg --with-proj && \
    make -j6 && \
    make -j6 install
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221118/427f6985/attachment.htm>
