[gdal-dev] Latest GDAL version not transforming lat/lng into geom column
Moises Calzado mcalzado at carto.com
Mon Nov 21 01:20:35 PST 2022
Hello everyone,
We've just updated to the latest GDAL version (v3.6.0) and it seems that
something is not working correctly when trying to obtain a geom column from
a CSV containing latitudes and longitudes.
This is the command that is being used:
ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/ CSV:my_file.csv
> -simplify 0.00001 -dim XY -t_srs EPSG:4326 -lco GEOMETRY=AS_WKT -lco
> GEOMETRY_NAME=geom -lco CREATE_CSVT=YES -s_srs EPSG:4326 -oo
> KEEP_GEOM_COLUMNS=NO -oo
> X_POSSIBLE_NAMES=point_longitude,longitude,longitud,lon,Lon,Longitude,longitudedecimal,decimallongitude,decimallong,lng,long,Lng
> -oo
> Y_POSSIBLE_NAMES=latitude,latitud,lati,lat,Latitude,decimallat,decimallatitude,latitudedecimal,point_latitude
> -oo
> GEOM_POSSIBLE_NAMES=geom,Geom,geometry,the_geom,wkt,wkb,wkt_geometry,wkb_geometry
> -oo EMPTY_STRING_AS_NULL=YES -oo QUOTED_FIELDS_AS_STRING=NO -lco
> PRECISION=NO -oo AUTODETECT_SIZE_LIMIT=500000
The file that is being processed contains a column called lat and another
one called lon, and when I execute the same process on a docker container
running the version 3.5.1 of GDAL it works like a charm. We've also tried
to execute this process on the 3.5.3 version, and it also fails. Is that
expected?
Looking forward to your response,
Regards!
*Moises Calzado*
Support Engineer
(US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
<https://www.carto.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221121/15b3e361/attachment-0001.htm>
