[gdal-dev] Latest GDAL version not transforming lat/lng into geom column
Even Rouault even.rouault at spatialys.com
Mon Nov 21 04:07:30 PST 2022
Should be fixed per https://github.com/OSGeo/gdal/pull/6756
Le 21/11/2022 à 12:16, Rahkonen Jukka a écrit :
> Hi,
> Did you ever notice that the result from GDAL 3.5.1 is wrong as well?
> You csv file has coordinates with a comma as a decimal separator and
> enclosed between double quotes
> my_file.csv
> CD_MES,store_id,date_id,ticket_id,hour_id,lat,lon
> 202112,101,04/12/21,1,11,"19,38358","-99,183735"
> 202112,101,25/12/21,31,15,"19,38066","-99,183405"
> The result that you considered right cuts the decimals
> "POINT (-99 19)","202112","101",04/12/21,"1","11"
> and I think that it is worse result that not getting coordinates at all.
> Editing the csv file to present coordinates as numbers with point as a
> decimal separator gives correct result
> my_file.csv
> 202112,101,04/12/21,1,11,19.38358,-99.183735
> 202112,101,25/12/21,31,15,19.38066,-99.183405
> ogrinfo
> "POINT (-99.183735 19.38358)","202112","101",04/12/21,"1","11"
> "POINT (-99.183405 19.38066)","202112","101",25/12/21,"31","15"
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Rahkonen Jukka
> *Lähetetty:* maanantai 21. marraskuuta 2022 13.07
> *Vastaanottaja:* Moises Calzado <mcalzado at carto.com>
> *Kopio:* 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org)
> <gdal-dev at lists.osgeo.org>
> *Aihe:* Re: [gdal-dev] Latest GDAL version not transforming lat/lng
> into geom column
> Hi,
> I could reproduce with OSGeo4W version GDAL 3.6.0, released
> 2022/11/06.  I have also a bit older version GDAL 3.6.0dev from
> gisinternals.com, probably installed 2022-05-16, and that version
> finds the geometries. So if it is not because of differences in build
> systems then something has happened after mid of May 2022.
> -Jukka Rahkonen-
> *Lähettäjä:*Moises Calzado <mcalzado at carto.com>
> *Lähetetty:* maanantai 21. marraskuuta 2022 11.50
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> into geom column
> Hi Jukka,
> Thanks so much for taking a look at this.
> This is the result when running the command in the 3.5.1 version:
>     GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>     84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4326"]]
>     WKT,String,String,String,String,String
>     geom,CD_MES,store_id,date_id,ticket_id,hour_id
>     "POINT (-99 19)","202112","101",25/12/21,"31","15"
> And this is what I obtained in the 3.6.0 version:
> That's the file that I've used for testing:
> https://storage.googleapis.com/import-testing-stream/my_file.csv
> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fstorage.googleapis.com%2Fimport-testing-stream%2Fmy_file.csv&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C7597a8d011e749c72a0a08dacbb0844e%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638046256280278841%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=XU3u4Oy0HUhuyLS%2FBuDD6XSWoNzVqNYuv57zudr29yU%3D&reserved=0>
> El lun, 21 nov 2022 a las 10:28, Rahkonen Jukka
> (<jukka.rahkonen at maanmittauslaitos.fi>) escribió:
>     Hi,
>     Please add a one line test file “my_file.csv” so we can try to
>     reproduce. Confirm first that it fails with your GDAL version.
>     -Jukka Rahkonen-
>     *Moises Calzado via gdal-dev
>     *Lähetetty:* maanantai 21. marraskuuta 2022 11.21
>     *Vastaanottaja:* gdal-dev at lists.osgeo.org
>     *Aihe:* [gdal-dev] Latest GDAL version not transforming lat/lng
>     into geom column
>     Hello everyone,
>     We've just updated to the latest GDAL version (v3.6.0) and it
>     seems that something is not working correctly when trying to
>     obtain a geom column from a CSV containing latitudes and longitudes.
>     This is the command that is being used:
>         ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/
>         CSV:my_file.csv -simplify 0.00001 -dim XY -t_srs EPSG:4326
>         -lco GEOMETRY=AS_WKT -lco GEOMETRY_NAME=geom -lco
>         CREATE_CSVT=YES -s_srs EPSG:4326 -oo KEEP_GEOM_COLUMNS=NO -oo
>         X_POSSIBLE_NAMES=point_longitude,longitude,longitud,lon,Lon,Longitude,longitudedecimal,decimallongitude,decimallong,lng,long,Lng
>         -oo
>         Y_POSSIBLE_NAMES=latitude,latitud,lati,lat,Latitude,decimallat,decimallatitude,latitudedecimal,point_latitude
>         -oo
>         GEOM_POSSIBLE_NAMES=geom,Geom,geometry,the_geom,wkt,wkb,wkt_geometry,wkb_geometry
>         -oo EMPTY_STRING_AS_NULL=YES -oo QUOTED_FIELDS_AS_STRING=NO
>         -lco PRECISION=NO -oo AUTODETECT_SIZE_LIMIT=500000
>     The file that is being processed contains a column called lat and
>     another one called lon, and when I execute the same process on a
>     docker container running the version 3.5.1 of GDAL it works like a
>     charm. We've also tried to execute this process on the 3.5.3
>     version, and it also fails. Is that expected?
>     Looking forward to your response,
>     Regards!
>     *Moises Calzado*
>     Support Engineer
>     (US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
>     Lähettäjä poisti kuvan.
>     <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.carto.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C7597a8d011e749c72a0a08dacbb0844e%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638046256280278841%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=1A8HxLvT6%2FV0p9wIm6AReJJebpOPu3t%2Br6WRm6mRhN8%3D&reserved=0>
> *Moises Calzado*
> Support Engineer
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221121/d7fdcaa3/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221121/d7fdcaa3/attachment-0001.jpg>
