[gdal-dev] SortIncludes was Re: Motion: adopt RFC69 C/C++ Code Formatting
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Nov 24 12:47:32 PST 2022
clang-format keeps the blocks independent, yes. We usually divide in three
(or more) blocks: internal headers, third party, std. But it is a matter of
taste, of course.
This is the example of a file that uses gdal:
#pragma once
#include "CommandOptions.h"
#include <gdal_priv.h>
#include <gdal_utils.h>
#include <ogr_feature.h>
#include <ogr_spatialref.h>
#include <ogrsf_frmts.h>
#include <memory>
#include <stdexcept>
Some includes may have special conditions. Then just use blocks to keep
things in order. Also aesthetic order.
Or use  // clang-format off/on to not order something that is very special.
Anyhow, all this is a mater of taste. But I am really happy when the file
is automagically nicely formatted just when I save it.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Thu, 24 Nov 2022 at 20:34, Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Thu, 24 Nov 2022, Javier Jimenez Shaw wrote:
> > In my opinion if the order of the includes affects the output there is
> > something wrong in the code. I hope md5 is not recommending the order.
> It turns out that although 'man md5' says:
>       #include <sys/types.h>
>       #include <md5.h>
> the header file /usr/include/md5.h includes <sys/types.h> very early,
> so there is no actual problem, at least on this platform - Ubuntu
> 22.10/kinetic.
> > In case you insist on keeping the order defined by the user
> >  ... you can just add a newline to separate the includes in blocks.
> > Clang-format keeps the contiguous blocks independent.
> There are times when setting environment variables changes the
> effects of a header, so it is a relief to hear that clang-format
> wont reorder includes around that.
> I find it interesting to note that, by default, flake8 wants python code
> to put 'Stdlib' and 'Third Party' imports to be in separate groups,
> whilst clang-format wants to sort
>    #include <>
> and
>    #include ""
> into one alphabetical list.
> Andrew C. Aitchison                      Kendal, UK
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221124/0f3dd77e/attachment.htm>
