[gdal-dev] Motion: adopt RFC69 C/C++ Code Formatting
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 28 09:17:41 PST 2022
Which version of clang-format are we using? (I saw 3.8 somewhere n the
code?) Older versions are not easy to get in modern operating systems. In
Ubuntu 22.04 the default is clang-format-14. It is specially hard in MacOS,
friends told me.
About the blame problems, we can do this:
https://akrabat.com/ignoring-revisions-with-git-blame/
Thanks for the work!
On Mon, 28 Nov 2022, 17:14 Even Rouault, <even.rouault at spatialys.com> wrote:
> Hi,
> +1 and I'm very much for the "Big reformat", otherwise as discussed with
> Alessandro, I'm afraid occasional contributors will mix substantial and
> formatting changes in the same commit. The Big reformat commit itself
> should be done with a dedicated github account, like we did with the
> "git mv gdal/* ." tree-reorganisation to avoid unfair commit statistics.
> I've just tested successfully the proposed clang-format pre-commit hook
> on Windows, so this shouldn't be an obstacle to contributors whatever
> their development environment.
> Even
> Le 24/11/2022 à 09:39, ElPaso a écrit :
> > Hi,
> > Motion:
> > Adopt RFC88: RFC69 C/C++ Code Formatting [1]
> > I have updated the RFC [1] to use pre-commit and I have created a
> > draft implementation of the pre-commit hook and the CI integration
> > with a GH workflow [2].
> > If adopted, we still have to agree on which coding style to apply (for
> > now I used a clang-format file I've found under gdal/scripts), but the
> > biggest decision is wether proceed with an initial "Big Reformat" or
> > an incremental one, my draft implementation supports both.
> > Kind regards.
> > [1]
> https://github.com/elpaso/gdal/blob/rfc69_cplusplus_formatting-text-only/doc/source/development/rfc/rfc69_cplusplus_formatting.rst
> > [2]
> > https://github.com/elpaso/gdal/tree/rfc69_cplusplus_formatting_revival
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221128/e6669c53/attachment.htm>
