[gdal-dev] GDAL compilation with driver OGR_PG
Even Rouault even.rouault at spatialys.com
Mon Nov 28 14:49:15 PST 2022
https://github.com/OSGeo/gdal/pull/6816 should make it much more obvious
with an explicit fatal error when explicitly enabling a driver whose
requirements are not met.
Le 28/11/2022 à 17:47, Johannes Paul a écrit :
> Perfect ! Thank you very much.
> Johannes
> On Mon, 28 Nov 2022 at 16:16, Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Johannes,
>     minimum or near-minimum builds are tricky because of inter-driver
>     dependencies.
>     You also need to add -DOGR_ENABLE_DRIVER_PGDUMP=ON
>     Cf
>     https://github.com/OSGeo/gdal/blob/b2c689436208e72518f4cd60fb5e27d6d985a621/ogr/ogrsf_frmts/CMakeLists.txt#L87:
>     ogr_dependent_driver(pg PostGIS
>     "GDAL_USE_POSTGRESQL;OGR_ENABLE_DRIVER_PGDUMP")
>     Even
>     Le 28/11/2022 à 15:55, Johannes Paul a écrit :
>>     Hello,
>>     i'm having trouble getting GDAL compiled on Centos 7 and 8 with
>>     OGR PostgreSQL driver.
>>     I used to compile GDAL using configure --with-pg=yes, which was
>>     working fine, however since v3.6.0 cmake shall be used, and I
>>     can't get OGR_PG driver enabled using the following cmake options:
>>     cmake3 .. -UGDAL_ENABLE_DRIVER_* -UOGR_ENABLE_DRIVER_*
>>     -DOGR_BUILD_OPTIONAL_DRIVERS=OFF
>>     -DGDAL_BUILD_OPTIONAL_DRIVERS=OFF
>>     -DCMAKE_INSTALL_PREFIX="${INSTALLDIR}"
>>     -DCMAKE_PREFIX_PATH="${INSTALLDIR}" -DCMAKE_BUILD_TYPE=Release
>>     -DGDAL_USE_INTERNAL_LIBS=WHEN_NO_EXTERNAL -DGDAL_USE_CURL=ON
>>     -DGDAL_USE_PNG=ON -DGDAL_USE_PNG_INTERNAL=OFF
>>     -DPostgreSQL_INCLUDE_DIR="${INSTALLDIR}"/include
>>     -DPostgreSQL_LIBRARY_RELEASE="${INSTALLDIR}"/lib/libpq.so
>>     -DGDAL_USE_POSTGRESQL=ON -DGDAL_USE_SQLITE3=ON -DGDAL_USE_ZLIB=ON
>>     -DGDAL_USE_ZLIB_INTERNAL=OFF -DBUILD_TESTING=OFF
>>     -DBUILD_PYTHON_BINDINGS=OFF -DBUILD_JAVA_BINDINGS=OFF
>>     -DBUILD_CSHARP_BINDINGS=OFF -DOGR_ENABLE_DRIVER_GPKG=ON
>>     -DOGR_ENABLE_DRIVER_SQLITE=ON -DOGR_ENABLE_DRIVER_PG=ON
>>     -DGDAL_ENABLE_DRIVER_PNG=ON
>>     I do get -- Found PostgreSQL: /opt/i4d/lib/libpq.so (found
>>     version "13.3"), however OGR_PG is still disabled.
>>     If I remove -UGDAL_ENABLE_DRIVER_* -UOGR_ENABLE_DRIVER_*
>>     -DGDAL_BUILD_OPTIONAL_DRIVERS=OFF, I do get the driver enabled
>>     however I'm expecting a minimal GDAL configuration, only with the
>>     drivers I need for the build.
>>     Thanks,
>>     Johannes
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221128/7dd50729/attachment.htm>
