[gdal-dev] compiling gdal: ogr_ODS error
Scott public at postholer.com
Sat Aug 26 08:02:41 PDT 2023
Parquet issue. Do you have apache-arrow installed?
https://arrow.apache.org/docs/index.html
If you cmake it and install it in the default path, gdal should find it.
I'm using apache-arrow 12.0.1 with gdal 3.7.1. Even solved this for me.
The OGDI may be a different issue. It seems to be looking for RPC which
may also need to be installed with the dev package.
Those are my *guesses*
On 8/26/23 04:06, andy wrote:
> Hi,
> if I try to compile gdal 3.7.1 on debian bullseye,
> cmake -D GDAL_USE_GEOS=ON -D GDAL_USE_PARQUET=ON ..
> cmake --build .
> I have this error:
> Scanning dependencies of target ogr_ODS
> [ 89%] Building CXX object
> ogr/ogrsf_frmts/ods/CMakeFiles/ogr_ODS.dir/ods_formula_node.cpp.o
> ogr/ogrsf_frmts/ods/CMakeFiles/ogr_ODS.dir/ods_formula.cpp.o
> ogr/ogrsf_frmts/ods/CMakeFiles/ogr_ODS.dir/ogrodsdatasource.cpp.o
> ogr/ogrsf_frmts/ods/CMakeFiles/ogr_ODS.dir/ogrodsdriver.cpp.o
> [ 89%] Built target ogr_ODS
> Scanning dependencies of target ogr_OGDI
> ogr/ogrsf_frmts/ogdi/CMakeFiles/ogr_OGDI.dir/ogrogdidatasource.cpp.o
> In file included from
> /home/aborruso/lavagna/tmp/gdal-3.7.1/ogr/ogrsf_frmts/ogdi/ogrogdi.h:41,
>                   from
> /home/aborruso/lavagna/tmp/gdal-3.7.1/ogr/ogrsf_frmts/ogdi/ogrogdidatasource.cpp:30:
> /usr/include/ogdi/ecs.h:9:10: fatal error: rpc/rpc.h: No such file or
> directory
>      9 | #include <rpc/rpc.h>
> compilation terminated.
> gmake[2]: ***
> [ogr/ogrsf_frmts/ogdi/CMakeFiles/ogr_OGDI.dir/build.make:82:
> ogr/ogrsf_frmts/ogdi/CMakeFiles/ogr_OGDI.dir/ogrogdidatasource.cpp.o]
> Error 1
> gmake[1]: *** [CMakeFiles/Makefile2:10535:
> ogr/ogrsf_frmts/ogdi/CMakeFiles/ogr_OGDI.dir/all] Error 2
> gmake: *** [Makefile:160: all] Error 2
> How to solve it?
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto <https://medium.com/tantotanto>
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>   in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
