[gdal-dev] compiling gdal: ogr_ODS error
Scott public at postholer.com
Sun Aug 27 08:17:45 PDT 2023
Yeah, it's not finding something. FYI, I don't use the
GDAL_USE_PARQUET=ON, it just finds it. My Arrow/Parquet related output
looks like this (not real paths):
-- Arrow version: 12.0.1
-- Found the Arrow shared library: /opt/local/lib/libarrow.so.1200.1.0
-- Found the Arrow import library: ARROW_IMPORT_LIB-NOTFOUND
-- Found the Arrow static library: /opt/local/lib/libarrow.a
-- Parquet version: 12.0.1
-- Found the Parquet shared library: /opt/local/lib/libparquet.so.1200.1.0
-- Found the Parquet import library: PARQUET_IMPORT_LIB-NOTFOUND
-- Found the Parquet static library: /opt/local/lib/libparquet.a
-- ArrowAcero version: 12.0.1
-- Found the ArrowAcero shared library:
/opt/local/lib/libarrow_acero.so.1200.1.0
-- Found the ArrowAcero import library: ARROW_ACERO_IMPORT_LIB-NOTFOUND
-- Found the ArrowAcero static library: /opt/local/lib/libarrow_acero.a
-- ArrowDataset version: 12.0.1
-- Found the ArrowDataset shared library:
/opt/local/lib/libarrow_dataset.so.1200.1.0
-- Found the ArrowDataset import library: ARROW_DATASET_IMPORT_LIB-NOTFOUND
-- Found the ArrowDataset static library: /opt/local/lib/libarrow_dataset.a
On 8/27/23 00:42, andy wrote:
> Hi scott,
>  > Parquet issue. Do you have apache-arrow installed?
>  > https://arrow.apache.org/docs/index.html
> <https://arrow.apache.org/docs/index.html>
> I have installed pyarrow and compiled arrow/cpp.
> During "cmake -D GDAL_USE_GEOS=ON -D GDAL_USE_PARQUET=ON -D
> OGR_ENABLE_DRIVER_OGDI:BOOL=OFF ..", I have
> /usr/lib/x86_64-linux-gnu/libarrow_dataset.so.1300.0.0
> /usr/lib/x86_64-linux-gnu/libarrow_dataset.a
> The second one is not a blocking error.
> When I run "cmake --build ." I have the below error.
> Thank you
> Scanning dependencies of target GDAL
> [ 93%] Linking CXX shared library libgdal.so
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o: in function `GetFileSystem(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
> ogrparquetdriver.cpp:(.text+0x1193): undefined reference to
> `arrow::fs::FileSystemFromUriOrPath(std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&,
> std::allocator<char> >*)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o: in function `arrow::fs::FileSystem::FileSystem(arrow::io::IOContext const&)':
> ogrparquetdriver.cpp:(.text._ZN5arrow2fs10FileSystemC2ERKNS_2io9IOContextE[_ZN5arrow2fs10FileSystemC5ERKNS_2io9IOContextE]+0x23): undefined reference to `vtable for arrow::fs::FileSystem'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o: in function `VSIArrowFileSystem::VSIArrowFileSystem(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
> ogrparquetdriver.cpp:(.text._ZN18VSIArrowFileSystemC2ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE[_ZN18VSIArrowFileSystemC5ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE]+0x57): undefined reference to `arrow::fs::FileSystem::~FileSystem()'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o: in function `VSIArrowFileSystem::Equals(arrow::fs::FileSystem const&) const':
> ogrparquetdriver.cpp:(.text._ZNK18VSIArrowFileSystem6EqualsERKN5arrow2fs10FileSystemE[_ZNK18VSIArrowFileSystem6EqualsERKN5arrow2fs10FileSystemE]+0x2a): undefined reference to `typeinfo for arrow::fs::FileSystem'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x28): undefined reference to `arrow::fs::FileSystem::NormalizePath(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x30): undefined reference to `arrow::fs::FileSystem::PathFromUri(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x50): undefined reference to `arrow::fs::FileSystem::GetFileInfo(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x60): undefined reference to `arrow::fs::FileSystem::GetFileInfoAsync(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x68): undefined reference to `arrow::fs::FileSystem::GetFileInfoGenerator(arrow::fs::FileSelector const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0x88): undefined reference to `arrow::fs::FileSystem::DeleteDirContentsAsync(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xa0): undefined reference to `arrow::fs::FileSystem::DeleteFiles(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xc0): undefined reference to `arrow::fs::FileSystem::OpenInputStream(arrow::fs::FileInfo const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xd0): undefined reference to `arrow::fs::FileSystem::OpenInputFile(arrow::fs::FileInfo const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xd8): undefined reference to `arrow::fs::FileSystem::OpenInputStreamAsync(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xe0): undefined reference to `arrow::fs::FileSystem::OpenInputStreamAsync(arrow::fs::FileInfo const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xe8): undefined reference to `arrow::fs::FileSystem::OpenInputFileAsync(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTV18VSIArrowFileSystem[_ZTV18VSIArrowFileSystem]+0xf0): undefined reference to `arrow::fs::FileSystem::OpenInputFileAsync(arrow::fs::FileInfo const&)'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o: in function `VSIArrowFileSystem::~VSIArrowFileSystem()':
> ogrparquetdriver.cpp:(.text._ZN18VSIArrowFileSystemD2Ev[_ZN18VSIArrowFileSystemD5Ev]+0x32): undefined reference to `arrow::fs::FileSystem::~FileSystem()'
> /usr/bin/ld:
> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o:(.data.rel.ro._ZTI18VSIArrowFileSystem[_ZTI18VSIArrowFileSystem]+0x10): undefined reference to `typeinfo for arrow::fs::FileSystem'
> collect2: error: ld returned 1 exit status
> gmake[2]: *** [CMakeFiles/GDAL.dir/build.make:2638: libgdal.so.33.3.7.1]
> Error 1
> gmake[1]: *** [CMakeFiles/Makefile2:4667: CMakeFiles/GDAL.dir/all] Error 2
> gmake: *** [Makefile:160: all] Error 2
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
