[gdal-dev] compiling gdal: ogr_ODS error
Even Rouault even.rouault at spatialys.com
Mon Aug 28 07:19:52 PDT 2023
> Do you have some tips for me, to avoid the reference to 14?
The below error message suggest you have a dangling
/usr/local/lib/cmake/Arrow/ArrowTargets.cmake file ==> remove the
/usr/local/lib/cmake/Arrow directory
> Thank you
> CMake Error at /usr/local/lib/cmake/Arrow/ArrowTargets.cmake:88 (message):
>   The imported target "Arrow::arrow_shared" references the file
>      "/usr/local/lib/libarrow.so.1400.0.0"
>   but this file does not exist.  Possible reasons include:
>   * The file was deleted, renamed, or moved to another location.
>   * An install or uninstall procedure did not complete successfully.
>   * The installation package was faulty and contained
>      "/usr/local/lib/cmake/Arrow/ArrowTargets.cmake"
>   but not all the files it references.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
