[gdal-dev] Creation of a new driver from scratch
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Aug 30 06:38:56 PDT 2023
That sounds very similar to BIGTIFF option in GeoTIFF driver.
also a bit like GEOTIFF_VERSION option.
https://gdal.org/drivers/raster/gtiff.html
You can change that in the middle of the writing? wow.
On Wed, 30 Aug 2023 at 06:21, Abel Pau <a.pau at creaf.uab.cat> wrote:
> Hi again,
> I hope you have had nice holidays!
> In my journey to writing a new driver now I have a doubt.
> Our format can be written in two versions:
> v1.1: internal offsets and FID are only saved in 4 bytes. So, there is a
> limited number of FID you can read/write.
> v2.0: internal offsets and FID are only saved in 8 bytes. So, there is a
> huge number of FID you can read/write.
> I am interested in proportionate 3 ways of proceeding when a used calls
> translation from one format to our format.
> way 1: force to write V1.1 and stop writing features if the limit is
> reached.
> way 2: force to write V2.0 (and stop writing features if the limit is
> reached (it will no happen in a near future, I think)).
> way 3: leave that the program decides if V1.1 is not enough and then it
> changes automatically to V2.0. It does it in the middle of the process,
> when FID or some used internal offset gets the limit.
> So, my questions:
> 1.- Which ogr2ogr parameter is the best for doing that?
>         -f? specificating "MiraMon V1.1" or "MiraMonV2.0" or "MiraMon"
> (automatic way).
>       Or there is another way I haven't seen (I've read all options in
> https://gdal.org/programs/ogr2ogr.html#ogr2ogr)
> 2.- When using -progress some points appear on screen informing the
> progress. At the end of the progress (or sometimes driver requires) there
> is a gap of time that driver is writing some pendant information.
> There is any way to inform the user what the process is doing?
> Thanks in advance. I appreciate all your always kind answers.
> Abel.
> -----Mensaje original-----
> De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau
> Enviado el: divendres, 9 de juny de 2023 12:11
> Para: Even Rouault <even.rouault at spatialys.com>
> CC: gdal-dev at lists.osgeo.org
> Asunto: Re: [gdal-dev] Creation of a new driver from scratch
> Hi again.
> Finally I managed to use CMake to create a Visual Studio sln. And it's
> beautiful see all drivers there.
> But it's not crear for me what I have to modify (Cmakelist.txt,.. or
> something else) to include the new driver. I need it to be there to be able
> to debug.
> I created a copy of, let's say, Shape and modified the Cmakelists.txt in
> an apropriate way... but I miss something because recompiling and
> rebuilding doesn't change anything and my driver is not in the project.
> Anyone can make me a simple list of which files I have to modify?
> THANKS in advance!!!
> Abel.
> De: Even Rouault <even.rouault at spatialys.com> Enviado el: divendres, 2 de
> juny de 2023 20:34
> Para: Abel Pau <a.pau at creaf.uab.cat>
> CC: gdal-dev at lists.osgeo.org; Howard Butler <howard at hobu.co>
> > It is indeed desired that the code style of the contribution matches
> GDAL's style to some degree. GDAL provides a .clang-format file that might
> be helpful when you are editing to provide some automated conformance.
> Cf https://gdal.org/development/dev_practices.html#commit-hooks also to
> install pre-commit hooks to ensure the formatting is OK & fix it if not.
> https://gdal.org/development/rfc/rfc8_devguide.html also gives some hints
> on the general development practices. Generally try to stick with the
> conventions you observe in source code of drivers you take inspiration from.
> > You might be able to build a sln file using GDAL's CMake configuration,
> but there is no standard documentation about how to do this. Do know that
> most any configuration you provide must build and work with the standard
> GDAL CMake configuration which is typically invoked through the command
> line.
> The source of "truth" will be the CMakeLists.txt file.
> sln files are just a possible by-product of CMake that isn't stored in git.
> You may just google "Cmake visual studio" as there's nothing GDAL specific
> regarding this topic. ==>
> https://learn.microsoft.com/en-us/cpp/build/cmake-projects-in-visual-studio?view=msvc-170
> among other links that you'll get
> >> ·         Once I have a Visual Studio solution (sln) to inspire myself,
> how should I proceed to create the driver? Is there any pre-existing
> pattern or template to follow?
> > Find an existing raster or vector driver in the project that matches
> MiraMon's vector or raster format and use it as a skeleton.
> >> I would like to be able to debug it.
> > Familiarize yourself with GDAL's tests (a good place to learn is to look
> at GDAL's CI configuration), get tests running locally on your machine, and
> then write tests that provide test coverage for your raster or vector
> driver.
> For vector drivers, the test_ogrsf utility that is built with GDAL is used
> by most unit tests of vector drivers to check their compliance w.r.t
> expectations of what a driver should do/not do. Not that of course this is
> only generic testing. You also need to add tests that check that the
> content you read from a test file is the one you expect.
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230830/81963e22/attachment.htm>
