[gdal-dev] multidim arraySpecs/GetView
Even Rouault even.rouault at spatialys.com
Thu Aug 31 13:14:14 PDT 2023
Michael,
> Hi, hoping to check my syntax ... or expectations ... I'm expecting
> this to subset by step the 20x20 array in this netcdf, but getting no
> change in python MultiDimTranslate or at command line:
> ds = gdal.OpenEx('gdrivers/data/netcdf/byte_no_cf.nc
> <http://byte_no_cf.nc>', gdal.OF_MULTIDIM_RASTER)
> nds = gdal.MultiDimTranslate("/vsimem/array_view.zarr", ds,
> format="Zarr", arraySpecs=['name=Band1,view=[::2,::4]'])
> nds.GetRootGroup().OpenMDArray("Band1").GetShape()
> # (20, 20)
This was a bug. Fixed per https://github.com/OSGeo/gdal/pull/8297
A way of working it around is to use  scaleAxesSpecs=['x(4)', 'y(2)']
instead
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230831/8d3c6262/attachment.htm>
