[gdal-dev] sqlite dialect: OpenFileGDB and FID Column selection
andy aborruso at gmail.com
Thu Aug 31 14:36:18 PDT 2023
if I run
ogr2ogr -f CSV /vsistdout/ data.gdb  -sql "
SELECT OBJECTID from table_EDF_IS limit 1"
I have
OBJECTID,
"1"
Instead, if I run
ogr2ogr -f CSV /vsistdout/ data.gdb  -dialect sqlite  -sql "
I have this error
ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(SELECT OBJECTID from
table_EDF_IS   limit 1): no such column: OBJECTID
What's the way to use sqlite dialect and select OBJECTID/FID field?
If I use ogrinfo I have "FID Column = OBJECTID"
I'm using GDAL 3.8.0dev-c95490018a, released 2023/07/21
Thank you,
Andrea
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230831/c30a1901/attachment.htm>
