[gdal-dev] sqlite dialect: OpenFileGDB and FID Column selection
andy aborruso at gmail.com
Thu Aug 31 23:53:36 PDT 2023
Hi Jukka,
On Fri, 1 Sept 2023 at 07:42, Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> When the SQLite dialect is used, a temporary SQLite database is created.
> OBJECTID is a feature identifier (FID) and I guess that the FID gets
> converted into a primary key with the SQLite defaults. So maybe you can
> find the OBJECTID from ROWID.
it works, thank you very much.
Maybe a little related note in the documentation would do. What do you
think about it?
Thank you again
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230901/b6eaf2fa/attachment.htm>
