[gdal-dev] [EXTERNAL] [BULK] Re: Is there a way to load a custom driver without a declaration in gdal_frmts.h?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Mon Dec 11 08:30:59 PST 2023
Excellent, thanks.
Date: Monday, December 11, 2023 at 11:24 AM
To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>, Laurențiu Nicola <lnicola at dend.ro>, "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] [EXTERNAL] [BULK] Re: Is there a way to load a custom driver without a declaration in gdal_frmts.h?
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Le 11/12/2023 à 17:17, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev a écrit :
Thanks, that looks promising.
Does GDAL automatically call `AutoLoadDrivers`?  If not, do team members need to force a call to that?
GDALAllRegister() which is normally called by all standard code using GDAL calls it: https://github.com/OSGeo/gdal/blob/54890592b410d95a59b4b07c0b499ca383005514/frmts/gdalallregister.cpp#L319
Even
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org><mailto:gdal-dev-bounces at lists.osgeo.org> on behalf of Laurențiu Nicola via gdal-dev <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Reply-To: Laurențiu Nicola <lnicola at dend.ro><mailto:lnicola at dend.ro>
Date: Monday, December 11, 2023 at 11:13 AM
To: "gdal-dev at lists.osgeo.org"<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] [BULK] Re: [gdal-dev] Is there a way to load a custom driver without a declaration in gdal_frmts.h?
Hi Jesse,
https://gdal.org/api/gdaldriver_cpp.html#_CPPv4N17GDALDriverManager15AutoLoadDriversEv should answer your question.
Laurentiu
On Mon, Dec 11, 2023, at 18:11, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev wrote:
I know drivers can be built as plugins, but can they be detected / used by GDAL if they are not registered via gdal_frmts.h?  It doesn’t seem so.  Is this a C++ ABI restriction?  We’d like to provide members of our team an internal and custom gdal driver implementation without each of them needing a special GDAL build.
Best,
Jesse
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231211/04dcd560/attachment-0001.htm>
