[gdal-dev] Why Open() inside QuietDelete()?
Even Rouault even.rouault at spatialys.com
Thu Dec 14 08:59:41 PST 2023
Le 14/12/2023 à 17:36, Abel Pau via gdal-dev a écrit :
> Hi, today I have a very inside-code question...
> I’m wondering why when I want to translate from .SHP to MiraMonFile
> (.PNT) and the destinatination file already exists I seems that the
> call stack reveals a way that is weird for me and I would like to
> understand:
> Translate->Create->(then, as it extist) QuietDelete ->Detele
> ->Open.... *(why Open if I have to delete?)*
The answer lies in the code:
https://github.com/OSGeo/gdal/blob/master/gcore/gdaldriver.cpp#L1642
The default Delete() implementation needs to know the file list
composing the dataset (for example shapefile datasets are made of
multiple files) by calling GDALDataset::GetFileList()
An alternative is that your driver implements the GDALDriver::pfnDelete
callback, but I would do that only if the Open() in your driver is
particularly slow (most drivers have a fast Open() method)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231214/e13010f5/attachment.htm>
