[gdal-dev] Custom raster driver startup issues
Even Rouault
even.rouault at spatialys.com
Thu Dec 14 13:45:32 PST 2023
Actually, I remember now that on Linux I've observed plugin loading
issues specific to loading in Python when I forget to link the plugin to
libgdal itself. This doesn't show up when loading the plugin from a GDAL
command line utility.
Le 14/12/2023 à 22:19, Even Rouault via gdal-dev a écrit :
> - If you build a plugin against GDAL X.Y, you must run it against GDAL
> X.Y, and not an earlier or later version since the C++ ABI changes
> between feature versions (you should however be able to use a plugin,
> built against X.Y.some_patch_version, against X.Y.another_path_version)
> - The error you get about specified procedure not found generally
> indicate that your plugin links to some library that is not found in
> the PATH / LD_LIBRARY_PATH. dlopen() / LoadLibrary() aren't super
> verbose about the reasons. You might have to use ldd or
> DependencyWalker to figure out the runtime linking issue.
> - If you use GDALRegister_X(), then your DLL must be called exactly
> "gdal_X.dll" / "gdal_X.so" . Or use "GDALRegisterMe()" as the
> registration function. GDALRegister_X or GDALRegisterMe must have C
> export style (extern "C").
> - Before trying GDALOpen(), check with "gdalinfo --format X" that your
> driver is loaded.
> Le 14/12/2023 à 21:52, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS
> AND APPLICATIONS INC] via gdal-dev a écrit :
>> Hi,
>> After carefully following the advice here on the lists and the Raster
>> driver tutorial GDAL isn’t loading the driver.
>> I am relying on the AutoLoadDrivers function.
>> When I GDALAllRegister(), followed by a
>> GDALOpen(“path/to/custom/raster.ext”, RA_ReadOnly);, GDAL states that
>> the file is not recognized as a supported file format. The
>> application was built against the exact version of GDAL used to link
>> the custom driver code. GDAL 3.7.2
>> I tried running an older GDAL version (3.6.3) in a python
>> environment. When I `from osgeo import gdal`, there are two errors
>> that are printed.
>> 1. Can’t load requested DLL – then it printed the full path and file
>> name of the driver .dll, so it can find it!
>> 2. The specified procedure could not be found
>> These look like python specific error messages to me, and probably
>> stem from a gdal version mismatch. I’m assuming #2 is emitted in a
>> trivial sense because the .dll could not be opened. Curiously the
>> error message was printed twice. I did not expect this to work but
>> my hope was to see a more detailed error message.
>> I have exported the GDALRegister_X() function, in accordance with the
>> documentation. The driver code compiles cleanly and follows almost
>> verbatim with the tutorial.
>> How should I approach diagnosing the problem?
>> Best,
>> Jesse
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231214/40a9f705/attachment-0001.htm>
