[gdal-dev] Under what (if any) conditions would GDALWriteBlock modify data buffer?
Fitch, Simeon fitch at astraea.io
Sun Dec 17 14:09:09 PST 2023
The last argument to function `CPLErr GDALWriteBlock(GDALRasterBandH, int,
int, void*)`, pointing to the block array, is not `const`.  I can't find
anything in the documentation discussing ownership, etc. but need to know
what kind of invariants can be assumed here.
Are there (driver dependent?) circumstances where `GDALWriteBlock` will
mutate the given array, or can callers assume it's effectively `const
void*`?
Thanks,
Simeon
The content of this email is intended for the person or entity to which it
is addressed only. This email may contain confidential information. If you
are not the person to whom this message is addressed, be aware that any
use, reproduction, or distribution of this message is strictly prohibited.
If you received this in error, please contact the sender and immediately
delete this email and any attachments.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231217/024d8506/attachment.htm>
