[gdal-dev] gpkg related tables extension
Even Rouault even.rouault at spatialys.com
Tue Dec 19 08:29:58 PST 2023
Karsten,
Le 19/12/2023 à 16:56, Karsten Tebling via gdal-dev a écrit :
> Hello,
> according to the docs
> (https://gdal.org/drivers/vector/gpkg.html#relationships) the
> geopackage driver is able to read, create, update and delete
> "relationships". I tried to convert some tables of a postgis database
> to geopackage, but there was no related tables extensions in the
> geopackage.
The driver supports the API to read & edit relationships, but ogr2ogr
doesn't have logic to copy relationships from the source dataset to the
target one, nor does the PostGIS implement the relationship API.
> The related tables extension is also not listed in the supported
> extensions
> (https://gdal.org/drivers/vector/gpkg.html#level-of-support-of-geopackage-extensions).
Was missing in that section of the doc. Just added
> Is it possible to convert postgis tables to a geopackage with related
> tables?
You'll have to use the relationship API to create them manually. Cf
python testing of the GPKG driver:
https://github.com/OSGeo/gdal/blob/master/autotest/ogr/ogr_gpkg.py#L6897
Even
http://www.spatialys.com
