[gdal-dev] Any difference between VRT SimpleSource and no-op ComplexSource?
Even Rouault even.rouault at spatialys.com
Thu Dec 21 05:51:24 PST 2023
Laurențiu,
> I noticed that gdalbuildvrt with no options produces VRTs that use
> ComplexSource, when SimpleSource would be sufficient. Is there any
> meaningful performance difference between the two? I know I should
> measure myself, I just didn't get to try it yet.
It only uses a ComplexSource when it needs to, that is to say when there
is nodata or a mask band. Otherwise it will use SimpleSource. There is a
performance hit in using ComplexSource when it is not needed. In 3.8,
there has been an optimization to improve ComplexSource performance in
common nodata-only scenarios: cf
https://github.com/OSGeo/gdal/commit/cd67491d3909f5f05160fa209609b38d973c42de
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231221/e2a20201/attachment.htm>
