[gdal-dev] Any difference between VRT SimpleSource and no-op ComplexSource?
Even Rouault even.rouault at spatialys.com
Thu Dec 21 06:27:10 PST 2023
> On Thu, Dec 21, 2023, at 15:51, Even Rouault wrote:
>> It only uses a ComplexSource when it needs to, that is to say when
>> there is nodata or a mask band.
> I didn't realize this. I think I'm hitting a corner case with
> -separate, which is practically the only way I've ever used it:
Ah, indeed, I now see the issue in that mode. Fixed per
https://github.com/OSGeo/gdal/pull/8986
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231221/e1239165/attachment.htm>
