[gdal-dev] Set axis order with ogr2ogr
Even Rouault even.rouault at spatialys.com
Wed Feb 8 02:09:49 PST 2023
Elena,
I almost choked when reading "I'm using GDAL 1.1.1". Do you realize this
version was released 16 years ago ? Even GDAL 2.4.4 is antiquated.
Nobody longer support those versions. Please upgrade to a recent (< 2
years) version first. I've just verified that ogr2ogr works just fine on
our file with a recent version
Even
Le 08/02/2023 à 10:40, Elena Ruiz a écrit :
> Hello, I need to do a conversion between GML to SHP vector files with
> the app ogr2ogr.exe, and be able to set the order of the axes
> TRADITIONAL_GIS_ORDER / AUTHORITY_COMPLIANT, in the OGR API
> documentation (ogr_srs_api.h), I found the following:
> /"This will honor the axis order advertised by the source and target
> SRS, as well as their “data axis to SRS axis mapping”. To have a
> behavior similar to GDAL < 3.0, the OGR_CT_FORCE_TRADITIONAL_GIS_ORDER
> configuration option can be set to YES."/
> And from here I have deduced that I could use the
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER tag to establish the order of the
> axes and I have used the following command line:
> /ogr2ogr -f "ESRI Shapefile" "C:\Users\elena\Downloads\Recinto.shp"
> "C:\Users\elena\Downloads\Recinto.gml" -co
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER YES/
> I am using GDAL 1.1.1 on x86, for this version of GDAL it does create
> the SHP file, it does not give an error when executed, but it does not
> make any change in the order of the axes of the destination file.
> But I have also tried it with version 2.4.4 for x64 and in this case
> it gives me the following errors:
> /ERROR 1: Field gml_id has a NULL content which is not allowed/
> /ERROR 1: Unable to write feature 0 from layer LandCoverUnit./
> /ERROR 1: Terminating translation prematurely after failed/
> /translation of layer LandCoverUnit (use -skipfailures to skip errors)/
> I attach an example file in the following link:
> https://aplitop.sharefile.com/d-scfcb397f54a649598913d6ae00d0d398
> I hope someone can tell me how I can do what I need, thanks and regards.
> *Elena Ruiz *
> Sofware Development & Technical Support
> Tel. +34 952 43 97 71
> eruiz at aplitop.com
> Sumatra, 9 - 29190 Málaga (Spain)
> *www.aplitop.com
> <https://www.facebook.com/AplitopSL/> <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>*
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protección de Datos
> 2016/679), we inform you that the data and the information you provide
> us through this medium will be used by APLITOP, S.L., with C.I.F.
> B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order
> to answer your questions and inform you about our products. The data
> provided will be kept as long as it does not request its cessation and
> will not be transferred to third parties except in cases where there
> is a legal obligation. You have the right to access your personal
> data, correct inaccurate data or request its deletion when the data is
> no longer necessary for the purposes that were collected, as well as
> any rights recognized in the RGPD 2016/679
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/82e04551/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/82e04551/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/82e04551/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/82e04551/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/82e04551/attachment-0003.png>
