[gdal-dev] AWS Lambda layer with GDAL python bindings
Joe Lee hyoklee at hdfgroup.org
Wed Feb 8 06:35:57 PST 2023
This worked quite well in 2019 with a few hacks:
https://github.com/developmentseed/geolambda
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Ari Jolma <ari.jolma at gmail.com>
Date: Wednesday, February 8, 2023 at 1:42 AM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] AWS Lambda layer with GDAL python bindings
I need an AWS Lambda layer with GDAL python bindings, for "from osgeo
import gdal", but it seems difficult to make such a layer.
In fact all I need is gdal.Open and gdal.BuildVRT - I have not dug
deeper into rasterio, can it do those?
Anyway, I installed GDAL on a machine with python 3.8 as that's what to
lambda runtime will be, and from there copied files to a zip with /lib
and /python. The /lib is for the shared objects. I have now 94 libraries
there. The error I now get from
try
     from osgeo import gdal
except
in the lambda is
ImportError: /lib64/libm.so.6: version `GLIBC_2.27' not found (required
by /opt/lib/libgdal.so.29)
this seems to be a problem as that's the lambda's libm and not the libm
in /lib, which I assume should work.
Anybody know a solution? I tried some recipes I found from the net howto
build such a layer but they did not work for me out of the box, so I
tried myself.
Best,
Ari
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/0f24543d/attachment-0001.htm>
