[gdal-dev] -sql switch in gdal_rasterize
Scott public at postholer.com
Sat Feb 11 13:14:59 PST 2023
Other gdal utilities that use the -sql switch allow you to specify a
path to an sql file preceded with the @ symbol, such as:
-sql @/path/to/source.sql
Is there a way to do this with gdal_rasterize? Adding the above to an
--optfile returns the same error as doing it on the command line.
TIA
www.postholer.com
