[gdal-dev] Call for discussion on RFC 92 text: WKB Only geometries
Even Rouault even.rouault at spatialys.com
Sun Feb 12 15:00:55 PST 2023
> This RFC seems to have some things in common with the direct access to
> compressed raster blocks. Both by-pass the older raster and vector
> data models, yes? And they're quite specific to certain formats. Do
> you anticipate that GDAL and OGR will continue to develop more
> specialty APIs in addition to the general ones?
I have no preconceived ideas. I'd say that specialized API have their
place when they bring enough value, and don't do that at the cost of
complicating things that don't benefit from them. RFC 92 just doesn't
pass my own criteria (my vote for it would be 0 in its current state,
but maybe someone will want to restart from it and give it a second life).
Even
> On Sat, Feb 4, 2023, 11:55 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Hi Sean,
>>     but wouldn't it be possible for all OGRFeatures to carry WKB data
>>     by default and add a method to provide it to callers?
>     My understanding of what you propose would involve massive code
>     rewrites in all drivers and wouldn't be desirable from a
>     performance point of view, because most drivers can't generate WKB
>     easily (PostGIS and GPKG are the exceptions rather the norm). So
>     either all other drivers should be modified to compose WKB at hand
>     (massive coding effort. Probably several weeks of effort and
>     significant risk of regressions). Or get it from the ExportToWkb()
>     method of the OGRGeometry instance they currently build, but then
>     you pay the price in memory and CPU time to generate WKB that
>     might not be consumed by users.
>     | And only construct an OGRGeometry when it's asked for? Such as
>     when GetGeometryRef is called?
>     Good point, we could both make GetGeometryRef() and
>     GetGeomFieldRef() virtual methods whose default implementation
>     would be the same as currently, ie. return the value of the
>     corresponding member variable in the base OGRFeature class stored
>     with SetGeometry[Directly]()/SetGeomField[Directly]()
>     And add a new virtual method:
>     virtual GByte* OGRFeature::GetWKBGeometry(int iGeomField, size_t*
>     pnOutSize) const
>     whose default implementation would just use
>     GetGeomFieldRef(iGeomField)->ExportToWkb().
>     The few drivers that can provide a more efficient implementation
>     (GPKG typically) would create a derived class OGRFeatureGPKG with
>     a specific implementation of those new virtual methods to avoid
>     systematic OGRGeometry instantiation. The only drawback I see is
>     that making GetGeometryRef() and GetGeomFieldRef() virtual would
>     have a slight performance impact, but probably small enough.
>     But fundamentally I'm wondering if RFC 92 hasn't been made mostly
>     out fashioned now that we have RFC 86. RFC 86 generally leads to
>     2x speed-up or more on real-world datasets compared to OGRFeature
>     iteration (as measured by the bench_ogr_c_api vs bench_ogr_batch
>     utilities) on drivers that have implemented it (currently Arrow,
>     Parquet, FlatGeoBuf, GPKG), whereas RFC 92 only applies to GPKG &
>     PostGIS and in the best - artificial - case only lead to 30% speed-up.
>     Of course, adopting RFC 86 requires significant effort from GDAL
>     users, but the benefit is really measurable whereas with RFC 92 it
>     would be marginal in most scenarios. As far as I can tell, the
>     performance boost of RFC 86 comes mostly from saving creation &
>     destruction of millions of OGRFeature instances, its array
>     members, string attributes, geometries objects, more than the
>     columnar organization of the ArrowArray data structures. In the
>     GeoPackage driver, I've also shown that it makes it possible for
>     efficient multi-threading pre-fetching, totally transparent for
>     the user.
>     But to avoid selling false hopes, the benefit of RFC 86 in
>     end-to-end scenarios would probably drop significantly (at least
>     if looking at performance gain in percentage. The absolute
>     performance savings on the GDAL side would remain) if you need to
>     recreate individual features (QGIS' QgsFeature or MapServer'
>     msShape objects) from the content of ArrowArray. So this is likely
>     a complete shift of concepts that would be required.
>     Even
>>     On Tue, Jan 31, 2023 at 4:27 AM Even Rouault
>>         Hi,
>>         Please find for review "RFC 92 text: WKB Only geometries" at
>>         https://github.com/OSGeo/gdal/pull/7149
>>         This RFC provides shortcuts to avoid instantiation of full
>>         OGRGeometry
>>         instances
>>         in scenarios where only the WKB representation of geometries
>>         is needed. The
>>         hope is to save CPU time.
>>         This is something I wanted to at least experiment. I've mixed
>>         feelings
>>         if it's something we actually want to adopt.
>>         Even
>>         http://www.spatialys.com
>>         My software is free, but my time generally not.
>>         _______________________________________________
>>         gdal-dev mailing list
>>         gdal-dev at lists.osgeo.org
>>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>     Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230213/999fc1b7/attachment-0001.htm>
