[gdal-dev] [Board] Travis usage of GRASS
Even Rouault even.rouault at spatialys.com
Tue Feb 14 10:05:33 PST 2023
2 concurrent builds would probably be fine.
(I also see we use s390x and Graviton2 for PROJ. It is sometimes useful
because of subtle floating point differences that pop up and make the
regression test suite fail. Easier to catch them at the time they are
introduced rather that after release when the maintainer of a Linux
distro which builds for all possible architectures reports a test
failure in one of those archs to which you don't have easy access to)
Le 14/02/2023 à 18:50, Michael Smith a écrit :
> Even,
> If its actively being used, that’s fine. Was just re-evaluating after talking with Howard. Could we drop the concurrency down without impacting GDAL, GRASS and other projects?
> And looks like I got the renewal dates swapped with mapserver. The OSGeo plan doesn’t renew until June. Right now we are on the:
> Premium plan 10 concurrent jobs with 30% discount.
> So if we do need to maintain, could we drop to 5 or 2 concurrent builds?
> Michael Smith
> OSGeo Treasurer
> From: Even Rouault <even.rouault at spatialys.com>
> Date: Tuesday, February 14, 2023 at 10:38 AM
> To: Michael Smith <michael.smith.erdc at gmail.com>, <wenzeslaus at gmail.com>, Markus Neteler <neteler at osgeo.org>, Veronica Andreo <veroandreo at gmail.com>
> Cc: <board at lists.osgeo.org>, "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Subject: Re: [Board] Travis usage of GRASS
> Hi,
> just reacting to "We were considering cancelling OSGeo’s subscription". For GDAL, our current use of Travis-CI is to test portability on the Graviton2 ARM64 and s390x big-endian platforms (we use github CI for x64 Linux/Win/Mac). For Graviton2, this is more the ARM64 side of things than the Graviton2 specific one, as ARM64 is the architecture of recent Apple hardware and there's no corresponding workers for github CI (not sure if there free CI solutions that can be integrated with github and offer ARM64 support?). s390x/big-endian use cases have probably little market relevance nowadays.
> Even
> Le 14/02/2023 à 18:26, Michael Smith via Board a écrit :
> After not seeing any builds for a while in Travis from Grass, I just saw one recently.
> We were considering cancelling OSGeo’s subscription but if this is something GRASS is actively using/depending on, we can maintain. We might scale back the subscription if its only lightly used those. I have to renew on Feb 19 so if you could let me know before then.
> Thanks,
> Mike
> Michael Smith
> OSGeo Treasurer
> Board mailing list
> mailto:Board at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/board
http://www.spatialys.com
