[gdal-dev] Error when trying to build Docker Images
Even Rouault even.rouault at spatialys.com
Tue Feb 14 10:15:10 PST 2023
Dual architecture amd64+arm64 builds are attempted by default (see
https://github.com/OSGeo/gdal/tree/master/docker#multi-arch-images),
which requires docker buildx to be setup|, or perhaps just ||binfmt to
support arm64 through qemu|||
If you just need amd64 builds, add "--platform linux/amd64" after ./build.sh
Le 14/02/2023 à 19:00, Dirk Stenger a écrit :
> All,
> Unfortunately, when trying to build the GDAL Docker Image on a local
> machine (Ubuntu 22.04), the build fails with an error:
> Executed commands and logging:
> ~/git/gdal/docker/ubuntu-small$ ./build.sh
> debconf: delayingpackage  configuration, since apt-utils is not installed
> Fetched 70.5 MB in 39s (1795 kB/s)
> Selecting previously unselectedpackage  libpython3.10-minimal:arm64.
> (Reading database ... 19054 files and directories currently installed.)
> Preparing to unpack .../libpython3.10-minimal_3.10.6-1~22.04.2_arm64.deb ...
> Unpacking libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Selecting previously unselectedpackage  libexpat1:arm64.
> Preparing to unpack .../libexpat1_2.4.7-1ubuntu0.2_arm64.deb ...
> Unpacking libexpat1:arm64 (2.4.7-1ubuntu0.2) ...
> Selecting previously unselectedpackage  python3.10-minimal:arm64.
> Preparing to unpack .../python3.10-minimal_3.10.6-1~22.04.2_arm64.deb ...
> Unpacking python3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Setting up libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Setting up libexpat1:arm64 (2.4.7-1ubuntu0.2) ...
> Setting up python3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> /var/lib/dpkg/info/python3.10-minimal.postinst: 51: /usr/bin/python3.10: Exec format error
> dpkg: error processingpackage  python3.10-minimal:arm64 (--configure):
>   installed python3.10-minimal:arm64package  post-installation script subprocess returned error exit status 126
> Errors were encounteredwhile  processing:
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> The command'/bin/sh -c . /buildscripts/bh-set-envvars.sh     && apt-get update -y
>     && DEBIAN_FRONTEND=noninteractive apt-get install -y --fix-missing
> --no-install-recommends        python3-dev${APT_ARCH_SUFFIX}
> python3-numpy${APT_ARCH_SUFFIX} python3-setuptools${APT_ARCH_SUFFIX}
>      libjpeg-dev${APT_ARCH_SUFFIX} libgeos-dev${APT_ARCH_SUFFIX}
>  libexpat-dev${APT_ARCH_SUFFIX} libxerces-c-dev${APT_ARCH_SUFFIX}
>    libwebp-dev${APT_ARCH_SUFFIX} libpng-dev${APT_ARCH_SUFFIX}
>  libzstd-dev${APT_ARCH_SUFFIX} bash zip curl
>  libpq-dev${APT_ARCH_SUFFIX} libssl-dev${APT_ARCH_SUFFIX}
> libopenjp2-7-dev${APT_ARCH_SUFFIX}
>  libspatialite-dev${APT_ARCH_SUFFIX}        autoconf automake sqlite3
> bash-completion'  returned a non-zero code: 100
> The same behavior occurs with ubuntu-full:
> ~/git/gdal/docker/ubuntu-full$ ./build.sh
> Fetched 466 MB in 3min 39s (2128 kB/s)
> Selecting previously unselectedpackage  libcap2:arm64.
> (Reading database ... 19051 files and directories currently installed.)
> Preparing to unpack .../libcap2_1%3a2.44-1build3_arm64.deb ...
> Unpacking libcap2:arm64 (1:2.44-1build3) ...
> Selecting previously unselectedpackage  libgpg-error0:arm64.
> Preparing to unpack .../libgpg-error0_1.43-3_arm64.deb ...
> Unpacking libgpg-error0:arm64 (1.43-3) ...
> Selecting previously unselectedpackage  libgcrypt20:arm64.
> Preparing to unpack .../libgcrypt20_1.9.4-3ubuntu3_arm64.deb ...
> Unpacking libgcrypt20:arm64 (1.9.4-3ubuntu3) ...
> Selecting previously unselectedpackage  liblz4-1:arm64.
> Preparing to unpack .../liblz4-1_1.9.3-2build2_arm64.deb ...
> Unpacking liblz4-1:arm64 (1.9.3-2build2) ...
> Setting up libcap2:arm64 (1:2.44-1build3) ...
> Setting up libgpg-error0:arm64 (1.43-3) ...
> Setting up libgcrypt20:arm64 (1.9.4-3ubuntu3) ...
> Setting up liblz4-1:arm64 (1.9.3-2build2) ...
> Selecting previously unselectedpackage  libsystemd0:arm64.
> (Reading database ... 19059 files and directories currently installed.)
> Preparing to unpack .../libsystemd0_249.11-0ubuntu3.6_arm64.deb ...
> Unpacking libsystemd0:arm64 (249.11-0ubuntu3.6) ...
> --no-install-recommends        libopenjp2-7-dev${APT_ARCH_SUFFIX}
> libcairo2-dev${APT_ARCH_SUFFIX}        python3-dev${APT_ARCH_SUFFIX}
>      libpng-dev${APT_ARCH_SUFFIX} libjpeg-dev${APT_ARCH_SUFFIX}
> libgif-dev${APT_ARCH_SUFFIX} liblzma-dev${APT_ARCH_SUFFIX}
> libgeos-dev${APT_ARCH_SUFFIX}        curl
> libxml2-dev${APT_ARCH_SUFFIX} libexpat-dev${APT_ARCH_SUFFIX}
>  libnetcdf-dev${APT_ARCH_SUFFIX} libpoppler-dev${APT_ARCH_SUFFIX}
> libpoppler-private-dev${APT_ARCH_SUFFIX}
> librasterlite2-dev${APT_ARCH_SUFFIX} swig ant
> libhdf4-alt-dev${APT_ARCH_SUFFIX} libhdf5-serial-dev${APT_ARCH_SUFFIX}
>        libfreexl-dev${APT_ARCH_SUFFIX} unixodbc-dev${APT_ARCH_SUFFIX}
>  mdbtools-dev${APT_ARCH_SUFFIX} libwebp-dev${APT_ARCH_SUFFIX}
>  liblcms2-2 libpcre3-dev${APT_ARCH_SUFFIX}
> libcrypto++-dev${APT_ARCH_SUFFIX} libfyba-dev${APT_ARCH_SUFFIX}
>  libkml-dev${APT_ARCH_SUFFIX} libmysqlclient-dev${APT_ARCH_SUFFIX}
> libogdi-dev${APT_ARCH_SUFFIX}        libcfitsio-dev${APT_ARCH_SUFFIX}
> openjdk-"$JAVA_VERSION"-jdk${APT_ARCH_SUFFIX}
> libzstd-dev${APT_ARCH_SUFFIX}        libpq-dev${APT_ARCH_SUFFIX}
> libssl-dev${APT_ARCH_SUFFIX} libboost-dev${APT_ARCH_SUFFIX}
>  autoconf automake bash-completion libarmadillo-dev${APT_ARCH_SUFFIX}
>        libopenexr-dev${APT_ARCH_SUFFIX} libheif-dev${APT_ARCH_SUFFIX}
>        libdeflate-dev${APT_ARCH_SUFFIX} libblosc-dev${APT_ARCH_SUFFIX}
> liblz4-dev${APT_ARCH_SUFFIX} libbz2-dev${APT_ARCH_SUFFIX}
>  libbrotli-dev${APT_ARCH_SUFFIX}
>  libarchive-dev${APT_ARCH_SUFFIX}     && rm -rf /var/lib/apt/lists/*'  returned a non-zero code: 100
> This is the used Docker version:
> docker --version
> Docker version 20.10.17, build 100c701
> I tried to build the /master/ branch and /release/3.5/ branch.
> Can anyone help why the build is failing?
> Kind regards,
> Dirk Stenger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230214/14a5fe32/attachment-0001.htm>
