[gdal-dev] How to build GDAL without dependency on libtiff.so or libjpeg.so
Even Rouault even.rouault at spatialys.com
Wed Feb 15 04:17:59 PST 2023
Assuming you're speaking about how to link against internal copy with
CMake builds, cf GDAL_USE_TIFF_INTERNAL and GDAL_USE_JPEG_INTERNAL at
https://gdal.org/development/building_from_source.html#tiff and
https://gdal.org/development/building_from_source.html#jpeg
Even if you set those, you can still get external libtiff or libjpeg
dependency, if you also link to a GDAL dependency that links against
those, like libgeotiff, librasterlite2, ...
Even
Le 15/02/2023 à 01:57, Fengting Chen a écrit :
> Hi,
> In the old build system, I was able to build GDAL 3.4 using
> “—with-libtiff=internal” and “—with-jpeg=internal” . However, ldd on
> libgdal.so shows that it still depends on libtiff.so and libjpeg.so.
> How to build GDAL without this dependency?
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230215/476347f6/attachment.htm>
