[gdal-dev] Segmentation fault while compiling
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Feb 15 16:06:20 PST 2023
Funny, I just got that same error (Windows). Apparently not fatal as I could do
ninja install
and all apparently went well
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Wednesday, February 15, 2023 11:44 PM
To: afernandez <afernandez at odyhpc.com>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Segmentation fault while compiling
This is a new Python script that runs the Python bindings and use PROJ functionality. Aren't you running into the issue of having 2 PROJ versions described in https://github.com/OSGeo/gdal/pull/7250?
If you don't need to run GDAL tests, you can add -DBUILD_TESTING=OFF to your CMake invokation and that will avoid running this script. But the crash indicates something fishy that might hit you at execution of your GDAL build
Le 16/02/2023 à 00:20, afernandez a écrit :
Hello,
I'm trying to compile GDAL from source in order to include the KEA components. My attempt at compiling (configured simply with cmake .. -DCMAKE_INSTALL_PREFIX=/usr) failed towards the end with a segmentation fault error, which I cannot figure out
[ 98%] Built target testlog
[ 98%] Building CXX object autotest/cpp/CMakeFiles/test_osr_set_proj_search_paths.dir/test_osr_set_proj_search_paths.cpp.o
[ 98%] Building CXX object autotest/cpp/CMakeFiles/test_osr_set_proj_search_paths.dir/main_gtest.cpp.o
[ 98%] Linking CXX executable test_osr_set_proj_search_paths
[ 98%] Built target test_osr_set_proj_search_paths
[ 98%] Building CXX object autotest/cpp/CMakeFiles/proj_with_fork.dir/proj_with_fork.cpp.o
[ 98%] Building CXX object autotest/cpp/CMakeFiles/proj_with_fork.dir/main_gtest.cpp.o
[ 98%] Linking CXX executable proj_with_fork
[ 98%] Built target proj_with_fork
[ 98%] Building CXX object autotest/CMakeFiles/pytest_runner.dir/pytest_runner.cpp.o
[ 98%] Linking CXX executable pytest_runner
[ 98%] Built target pytest_runner
Segmentation fault
make[2]: *** [autotest/CMakeFiles/run_setup_proj_db_tmpdir.dir/build.make:70: autotest/CMakeFiles/run_setup_proj_db_tmpdir] Error 1
make[1]: *** [CMakeFiles/Makefile2:12792: autotest/CMakeFiles/run_setup_proj_db_tmpdir.dir/all] Error 2
make: *** [Makefile:146: all] Error 2
Thanks.
P.S. OS is Ubuntu22.04 and architecture is aarch64; GDAL is cloned from Github
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/305a422f/attachment-0001.htm>
