[gdal-dev] [External] : Re: How to build GDAL without dependency on libtiff.so or libjpeg.so
Kai Pastor, DG0YT dg0yt at darc.de
Thu Feb 16 08:53:32 PST 2023
The dependency in PROJ is optional. If you build PROJ from source, it is
under your control.
Am 15.02.23 um 22:36 schrieb Fengting Chen:
> Thanks. I later found out that libproj has dependency on libtiff. And
> since libproj is required by GDAL, basically GDAL indirectly depends
> on external libtiff.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/51bb4765/attachment.htm>
