[gdal-dev] help with (docker) build workflow
Michael Sumner mdsumner at gmail.com
Sun Feb 19 10:08:01 PST 2023
I would like to build GDAL in an image on the basis of a dockerfile used
for CI, I'm confused by the layer process that copies the build outputs for
the final steps
https://github.com/OSGeo/gdal/blob/master/docker/ubuntu-small/Dockerfile#L231
I want to be able to run that image and then do my own builds with cmake -
but the layer COPY process doesn't include cmake or the other prereqs used
above (to save space in the image).
Is it easy to include the build capability as a layer-copy step?
Or is this perhaps a bad idea, I'm looking for the easiest way to get a
build system running with docker - I can unpick the builder/COPY process,
but maybe I'm missing something easy.
Thank you
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230220/fdc635ee/attachment.htm>
