[gdal-dev] gdal_rasterize parameters not working
Clive Swan cliveswan at gmail.com
Mon Jul 3 07:35:45 PDT 2023
I am trying to create a heatmap from a Shp Point feature.
The output is doesn’t cover the Shp??
I entered the following gdal gdal_rasterize parameters.
gdal_rasterize
-a hazard_l_1
 -te -4.822014 52.517355  1.757978  55.779307
-tr 0.1     0.1
-ts 2035 2069
"C:\Temp\PROJECTS\CCRT\ClimateChangeFME\Modelling\UK\Shp\Coastal\Coastal_Flooding_2000.shp" "C:\Temp\PROJECTS\CCRT\ClimateChangeFME\Modelling\UK\Maps\coastal_2000.tif"
It doesn’t use the field from - a hazard >> 52 to 82??
The Raster doesn’t cover the UK??
The raster should only cover the UK.
Any suggestions you would recommend to use??
Thanks
Clive
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230703/d4b4ad58/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230703/d4b4ad58/attachment-0001.png>
