[gdal-dev] Instructions for a new writing driver?
Laurențiu Nicola lnicola at dend.ro
Thu Jul 6 06:08:08 PDT 2023
I think some existing drivers already contain some C files, AIGRID for example. Others have a sdk subdirectory with library code in there. I don't think including your code as C will be a problem.
On the other hand, offering a C API for new drivers might be an interesting idea. Using C++ makes writing drivers in other languages a bit more complicated. But I know this wouldn't be trivial, since GDAL uses inheritance.
Laurentiu
On Thu, Jul 6, 2023, at 16:01, Abel Pau wrote:
> Hi again.
> I finally did that and I am happy.
> It would be helpful for us to be able to use our C functions to read and write some parts of our format instead of passing all of them to C++.
> I’d like doing that but it’s not possible for the moment convert all our code to C++.
> My proposal is use a ogrmiramondatasource.cpp, a ogrmiramondriver.cpp and a ogrmiramonlayer.cpp as all of the projects that are created and add our files from C as necessary.
> The main goal is adding only the necessary ones.
> The question: Is this possible? Can I simply add C files and use that functions from C++ files? Or do GDAL prefer doing it in another way?
> Sorry if it is written somewhere else but I couldn’t find it.
> Thanks again for your kind help.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230706/f2d6dd19/attachment.htm>
