[gdal-dev] A question of eficiency
Even Rouault even.rouault at spatialys.com
Fri Jul 7 03:32:17 PDT 2023
Abel,
At the minimum for the reading side of a vector driver, you need to
implement GetNextFeature().
If there is an efficient way of knowing the number of features without
iterating over the whole file (typically a field in a header giving that
number), you may implement GetFeatureCount(). If you don't implement it,
and code using your driver needs the feature count, the generic
implementation of OGRLayer::GetFeatureCount() will call GetNextFeature()
repeatdly until it returns NULL.
Not totally sure to understand your question about multielements. If you
have an instance of OGRGeometryCollection or any deriving class, there's
a getNumGeometries() method to get the number of parts
Even
Le 07/07/2023 à 11:33, Abel Pau a écrit :
> Hi,
> I would like to know if when we use the code of GDAL to program a
> driver (or whatever) in vectors (so, ogr) we can assume that we can
> know the number of elements we are going to import in any way or it
> would be possible not knowing that until NextFeature is empty (or
> something like that). So, there is any way to obtain this number of
> elements without doing a while? And in case of multielements its
> possible to know how many parts are there in total?
> I need that to write my format (I don’t explain the details cause I
> don’t get you bored :) )
> If anyone know that I’d appreciate an answer. Thanks in advance.
> Abel.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230707/46c1163e/attachment.htm>
