[gdal-dev] ogrinfo Unable to identify source geometry field with GDAL 3.7 but not 3.3?
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jul 12 05:19:41 PDT 2023
I also confirm the error with today's master (3.8.0dev).
Jukka is correct (same thinking as me), this works directly from CSV
(into PostgreSQL 15.3) now...
   ogr2ogr -f "PG:dbname=nz_address port=xxx user=xxx password=xxx"
nz-addresses.csv -oo GEOM_POSSIBLE_NAMES=WKT
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-07-12 8:58 a.m., Rahkonen Jukka wrote:
> Hi,
> I can confirm the error with GDAL 3.7.0. But because you have both .csv and .csvt it I wonder if there is any need to use .vrt. Output from "ogrinfo nz-addresses.csv" looks correct to me.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Gary Turner
> Lähetetty: keskiviikko 12. heinäkuuta 2023 4.36
> Vastaanottaja: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> Aihe: Re: [gdal-dev] ogrinfo Unable to identify source geometry field with GDAL 3.7 but not 3.3?
> As attached. I've removed some bulky documentation from the as-downloaded/supplied zip file.
> On 11/07/2023 8:20 pm, Even Rouault wrote:
>> Gary,
>> please provide a VRT and CSV that can reproduce this
>> Even
>> Le 11/07/2023 à 03:55, Gary Turner a écrit :
>>> Hi,
>>> Apologies if this isn't the right place to ask, but I am struggling
>>> to work out what's going on.
>>> I'm setting up a new windows machine to process address data provided
>>> by a local agency. I've downloaded new versions of software.
>>> I use ogr2ogr to load csv files via a vrt file into postgres. This
>>> works fine with my old setup, and has worked with various older
>>> versions as well.
>>> However with the latest ogr2ogr it fails. ogrinfo --version says GDAL
>>> 3.7.0, released 2023/05/02
>>> P:\bin\gdal37>.\ogrinfo.exe C:\temp\addresses.vrt
>>> INFO: Open of `C:\temp\addresses.vrt'
>>>        using driver `OGR_VRT' successful.
>>> 1: addressesERROR 1: Unable to identify source geometry field 'WKT'
>>> for geometry.
>>>   (None)
>>> but with an older version GDAL 3.3.1, released 2021/06/28
>>> P:\bin\gdal33>.\ogrinfo.exe C:\temp\addresses.vrt
>>> 1: addresses (Point)
>>> I get the same failure with ogr2ogr, but ogrinfo seemed simpler and
>>> there's a much less complicated command-line.
>>> I've cut this down to a one-field, one-line of csv example that does
>>> the same thing, if that's useful.
>>> Is this expected?
>>> Is there an easy work-around, that would work with both versions?
>>> Please let me know if I'm missing something obvious or just being
>>> dumb, or should  ask elsewhere.
>>> Thanks
>>> Gary
>>> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
