[gdal-dev] ogrinfo Unable to identify source geometry field with GDAL 3.7 but not 3.3?
Even Rouault even.rouault at spatialys.com
Wed Jul 12 05:57:18 PDT 2023
Gary,
This is very likely due to commit
https://github.com/OSGeo/gdal/commit/d60e71154c02b84b4c59cd61d3c21eb150f0b42a
: "when the .csvt indicates WKT and in default KEEP_GEOM_COLUMNS=YES
mode, prefix the geometry field name with 'geom_'" which was done to
avoid to have both a regular attribute field and a geometry field with
the same name, "WKT". Now the geometry column is called "geom_WKT"
3 possible ways of fixing this:
- likely slightly most performant one to switch to using the geometry
column: change <GeometryField field="WKT" reportSrcColumn="FALSE"> to
<GeometryField field="geom_WKT" reportSrcColumn="FALSE">
- or change <GeometryField field="WKT" reportSrcColumn="FALSE"> to
<GeometryField field="WKT" reportSrcColumn="FALSE" encoding="WKT">  to
ask to use the regular field WKT and interpret it as containing WKT
geometries
- or add <OpenOptions><OOI
key="KEEP_GEOM_COLUMNS">NO</OOI></OpenOptions> , for example after the
<SrcDataSource> element, so that the regular WKT field is not exposed by
the CSV driver, and thus only a geometry field WKT is exposed
The 2 later ones should likely be compatible with older GDAL versions too
Even
Le 12/07/2023 à 03:35, Gary Turner a écrit :
> As attached. I've removed some bulky documentation from the
> as-downloaded/supplied zip file.
> On 11/07/2023 8:20 pm, Even Rouault wrote:
>> Gary,
>> please provide a VRT and CSV that can reproduce this
>> Even
>> Le 11/07/2023 à 03:55, Gary Turner a écrit :
>>> Hi,
>>> Apologies if this isn't the right place to ask, but I am struggling
>>> to work out what's going on.
>>> I'm setting up a new windows machine to process address data
>>> provided by a local agency. I've downloaded new versions of software.
>>> I use ogr2ogr to load csv files via a vrt file into postgres. This
>>> works fine with my old setup, and has worked with various older
>>> versions as well.
>>> However with the latest ogr2ogr it fails. ogrinfo --version says
>>> GDAL 3.7.0, released 2023/05/02
>>> P:\bin\gdal37>.\ogrinfo.exe C:\temp\addresses.vrt
>>> INFO: Open of `C:\temp\addresses.vrt'
>>>       using driver `OGR_VRT' successful.
>>> 1: addressesERROR 1: Unable to identify source geometry field 'WKT'
>>> for geometry.
>>>  (None)
>>> but with an older version GDAL 3.3.1, released 2021/06/28
>>> P:\bin\gdal33>.\ogrinfo.exe C:\temp\addresses.vrt
>>> 1: addresses (Point)
>>> I get the same failure with ogr2ogr, but ogrinfo seemed simpler and
>>> there's a much less complicated command-line.
>>> I've cut this down to a one-field, one-line of csv example that does
>>> the same thing, if that's useful.
>>> Is this expected?
>>> Is there an easy work-around, that would work with both versions?
>>> Please let me know if I'm missing something obvious or just being
>>> dumb, or should  ask elsewhere.
>>> Thanks
>>> Gary
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
