[gdal-dev] Setting up bash completions on Ubunto 18
Eric Knudstrup eric at knudstrup.org
Sun Jul 16 16:58:16 PDT 2023
On 7/16/23 4:17 PM, Scott wrote:
> It looks like it's not in your path. If you built gdal with the
> default install prefix it should be in /usr/local/bin. Make sure
> that's in your path:
Ah, thanks.  The build doc didn't say I had to use pip3 to install the
Python tools.
