[gdal-dev] reading rat values from GDB raster
Even Rouault even.rouault at spatialys.com
Tue Jul 18 15:30:45 PDT 2023
William,
if you gdal_translate / CreateCopy() to a TIF, the RAT will be written
in the side car .aux.xml file. You can either use your favorite XML
edition tool to remove all columns but the one you are interested in, or
use the C/C++/Python GDALRasterAttributeTable API to create a new RAT
and copy values from the original one.
https://github.com/OSGeo/gdal/blob/master/autotest/gcore/rat.py might
serve as a starting point to get some sense of the API
Even
Le 18/07/2023 à 23:19, William Kyngesburye a écrit :
> I would like to convert a GDB raster with a multi column rat by writing out one of the columns. I can see the rat with gdalinfo but I can't figure out how to read values from the rat (other than the cell value) so they can be written to a new raster.
> William Kyngesburye
> <kyngchaos*at*kyngchaos*dot*com>
> <https://www.kyngchaos.com>
> Don't Panic
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
