[gdal-dev] libgdaljni.so installed in the wrong dir by default?
Landry Breuil breuil at craig.fr
Thu Jul 20 01:43:38 PDT 2023
working on debian and trying to reenable the libgdal-java package for
geoserver needs, i've figured out that since the switch to cmake, the
jars and the libgdalalljni.so files are now all installed in
GDAL_JAVA_INSTALL_DIR (which defaults to /usr/share/java).
previously with the autoconf-based builds, the jars went to
usr/share/java, and the libgdal*jni.so to usr/lib (then moved to
usr/lib/jni on debian).
was it an oversight ? it feels 'wrong' to have shared libs in
usr/share/java..
Landry Breuil
