[gdal-dev] libgdaljni.so installed in the wrong dir by default?
Even Rouault even.rouault at spatialys.com
Thu Jul 20 03:15:18 PDT 2023
Proposed change: https://github.com/OSGeo/gdal/pull/8125
Even
Le 20/07/2023 à 10:43, Landry Breuil a écrit :
> Hi,
> working on debian and trying to reenable the libgdal-java package for
> geoserver needs, i've figured out that since the switch to cmake, the
> jars and the libgdalalljni.so files are now all installed in
> GDAL_JAVA_INSTALL_DIR (which defaults to /usr/share/java).
> previously with the autoconf-based builds, the jars went to
> usr/share/java, and the libgdal*jni.so to usr/lib (then moved to
> usr/lib/jni on debian).
> was it an oversight ? it feels 'wrong' to have shared libs in
> usr/share/java..
http://www.spatialys.com
