[gdal-dev] NITF geotransform data erratic
Even Rouault even.rouault at spatialys.com
Thu Jul 20 09:45:25 PDT 2023
NITF base georeferencing using the IGEOLO field sucks because there's
not enough decimal digits to compute the full accuracy of a
geotransform, and thus when GDAL tries to reconstruct the geotransform
from the 4 corners (that's how georeferencing is stored), the threshold
to detect if the computed affine geotransform isn't always met.
I thought that a workaround would be to write the SDE TREs
(GEOPSB/PRJPSB and MAPLOB). There's a SDE_TRE=YES creation option for
that, but its implementation on the writing side is limited to
geographic coordinates, not projected ones (could potentially be
extended). So if you want to go with that route, you'll have to compose
the content of the TREs by yourself from the NITF spec, which is a non
trivial exercice. But actually, I'm wrong. MAPLOB cannot capture
rotating terms of a geotransform.
On the reading side, you can try to set the
GDAL_GCPS_TO_GEOTRANSFORM_APPROX_OK config option to a value larger than
the 0.25 pixel default value. cf
https://gdal.org/api/raster_c_api.html#_CPPv422GDALGCPsToGeoTransformiPK8GDAL_GCPPdi
Even
Le 20/07/2023 à 18:18, Nigus, Steve a écrit :
> I am doing a real-time SAR spot simulation where the SAR orbits a
> target point and saves a series of the georeferenced spot image
> files.  My initial implementation generated non-GDAL GeoTIFF or JPEG
> files.  I use a least-squares algorithm to develop the 6 affine
> geotransform values.  This all works fine, and the files display
> nicely in my GIS viewer.   I have since brought in GDAL 2.2.3 to
> create NITF files.  Unfortunately, over 30% of the NITF files lose the
> geotransform info.  Rather, they show generic GCPs.  The “good” NITF
> files display OK in my GIS viewer.  As a sanity test, I took a series
> of non-GDAL GeoTIFF files and ran them through gdal_translate to
> NITF.  Interestingly, around 30% of the NITF files again dropped the
> geotransform data.  I’ve attached below gdalinfo reports of a
> gdal_translate input GeoTIFF file and the output NITF file for a
> failing example. My geotransform data appears to be well-behaved.
> Question: What could cause geotransform data to be rejected?  Thanks…..
> Non-GDAL gdal_translate input GeoTIFF file:
> $ gdalinfo sar2023071722525322.tif
> Driver: GTiff/GeoTIFF
> Files: sar2023071722525322.tif
> Size is 1024, 1024
> Coordinate System is:
> PROJCS["VITAL SAR Simulation",
>     GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-81],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> GeoTransform =
> 586659.1336352756, -0.2027675805429681, -0.2274441341933198
> 2969181.096499263, -0.2274441341933198, 0.2027675805429681
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  ( 586659.134, 2969181.096) ( 80d 7'40.06"W, 26d50'29.50"N)
> Lower Left  ( 586426.231, 2969388.731) ( 80d 7'48.44"W, 26d50'36.30"N)
> Upper Right ( 586451.500, 2968948.194) ( 80d 7'47.64"W, 26d50'21.98"N)
> Lower Right ( 586218.597, 2969155.828) ( 80d 7'56.02"W, 26d50'28.78"N)
> Center      ( 586438.865, 2969168.462) ( 80d 7'48.04"W, 26d50'29.14"N)
> Band 1 Block=1024x8 Type=Byte, ColorInterp=Gray
> gdal_translate output NITF file:
> $ gdalinfo sar2023071722525322.nitf
> Driver: NITF/National Imagery Transmission Format
> Files: sar2023071722525322.nitf
> Size is 1024, 1024
> Coordinate System is `'
> GCP Projection =
> PROJCS["UTM Zone 17, Northern Hemisphere",
>     GEOGCS["WGS 84",
> DATUM["WGS_1984",
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> UNIT["Meter",1]]
> GCP[  0]: Id=UpperLeft, Info=
> (0.5,0.5) -> (586659,2969181,0)
> GCP[  1]: Id=UpperRight, Info=
> (1023.5,0.5) -> (586451,2968948,0)
> GCP[  2]: Id=LowerRight, Info=
> (1023.5,1023.5) -> (586219,2969156,0)
> GCP[  3]: Id=LowerLeft, Info=
> (0.5,1023.5) -> (586426,2969389,0)
> Metadata:
>   NITF_ABPP=08
> NITF_CCS_COLUMN=0
> NITF_CCS_ROW=0
> NITF_CLEVEL=03
>   NITF_ENCRYP=0
>   NITF_FBKGC= 0,  0,  0
> NITF_FDT=20021216151629
> NITF_FHDR=NITF02.10
>   NITF_FSCATP=
>   NITF_FSCAUT=
>   NITF_FSCLAS=U
>   NITF_FSCLSY=
>   NITF_FSCLTX=
>   NITF_FSCODE=
> NITF_FSCOP=00000
> NITF_FSCPYS=00000
>   NITF_FSCRSN=
>   NITF_FSCTLH=
>   NITF_FSCTLN=
>   NITF_FSDCDT=
>   NITF_FSDCTP=
>   NITF_FSDCXM=
>   NITF_FSDG=
> NITF_FSDGDT=
>   NITF_FSREL=
>   NITF_FSSRDT=
>   NITF_FTITLE=
>   NITF_IALVL=0
>   NITF_IC=NC
>   NITF_ICAT=VIS
>   NITF_ICORDS=N
> NITF_IDATIM=20021216151629
>   NITF_IDLVL=1
> NITF_IGEOLO=175866592969181175864512968948175862192969156175864262969389
> NITF_IID1=Missing
>   NITF_IID2=
> NITF_ILOC_COLUMN=0
> NITF_ILOC_ROW=0
>   NITF_IMAG=1.0
>   NITF_IMODE=B
> NITF_IREP=MONO
>   NITF_ISCATP=
>   NITF_ISCAUT=
>   NITF_ISCLAS=U
>   NITF_ISCLSY=
>   NITF_ISCLTX=
>   NITF_ISCODE=
>   NITF_ISCRSN=
>   NITF_ISCTLH=
>   NITF_ISCTLN=
>   NITF_ISDCDT=
>   NITF_ISDCTP=
>   NITF_ISDCXM=
>   NITF_ISDG=
>   NITF_ISDGDT=
> NITF_ISORCE=Unknown
>   NITF_ISREL=
>   NITF_ISSRDT=
>   NITF_ONAME=
>   NITF_OPHONE=
> NITF_OSTAID=GDAL
>   NITF_PJUST=R
> NITF_PVTYPE=INT
> NITF_STYPE=BF01
>   NITF_TGTID=
> Corner Coordinates:
> Upper Left (    0.0,    0.0)
> Lower Left  (    0.0, 1024.0)
> Upper Right ( 1024.0,    0.0)
> Lower Right ( 1024.0, 1024.0)
> Center      ( 512.0,  512.0)
> Band 1 Block=1024x1 Type=Byte, ColorInterp=Gray
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230720/bf1a3681/attachment-0001.htm>
