[gdal-dev] Issue with sub-dataset suffix
Simon Eves simon.eves at heavy.ai
Fri Jul 21 15:27:04 PDT 2023
We are dealing with some netCDF files on S3 which have multiple
sub-datasets.
Trying to do a simple gdalinfo using VSI paths.
Note you may need to have AWS_NO_SIGN_REQUEST=YES to access the file below.
This works, and gives a summary dump...
$ gdalinfo /vsis3/noaa-nwm-pds/nwm.20230720/short_range/
nwm.t00z.short_range.land.f001.conus.nc
This fails...
$ gdalinfo
/vsis3/noaa-nwm-pds/nwm.20230720/short_range/nwm.t00z.short_range.land.f001.conus.nc:
SOILSAT_TOP
ERROR 4:
`/vsis3/noaa-nwm-pds/nwm.20230720/short_range/nwm.t00z.short_range.land.f001.conus.nc:SOILSAT_TOP'
does not exist in the file system, and is not recognized as a supported
dataset name.
gdalinfo failed - unable to open
'/vsis3/noaa-nwm-pds/nwm.20230720/short_range/nwm.t00z.short_range.land.f001.conus.nc:
SOILSAT_TOP'.
If you ALSO specify the file type hint on the front of the path, it works...
$ gdalinfo
NETCDF:/vsis3/noaa-nwm-pds/nwm.20230720/short_range/nwm.t00z.short_range.land.f001.conus.nc:
SOILSAT_TOP
This seems like a bug. It should still be able to recognize and open the
file without the type hint, whether or not you provide a sub-dataset suffix.
Our system generally relies heavily on GDAL's usually-reliable ability to
recognize file types and load anything without such hints, so having to
provide that as well will be undesirable.
Simon Eves
Senior Rendering Engineer
+1 (415) 902-1996
<http://www.heavy.ai>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230721/9074c5dc/attachment.htm>
