[gdal-dev] Installing Arrow/Parquet
Even Rouault even.rouault at spatialys.com
Wed Jul 26 13:21:07 PDT 2023
You would need to build arrow-cpp and install it. If you install it in
the /usr prefix, GDAL CMake will autodetect it. Otherwise you'll have to
pass -DArrow_DIR=${install_prefix}/lib/cmake/Arrow
you may also install a prebuilt arrow-cpp package: cf
https://arrow.apache.org/install/  and GDAL CMake will autodetect it
Le 26/07/2023 à 21:17, Scott a écrit :
> I'm having a difficult time building gdal with Arrow/Parquet drivers
> on debian. Could someone show me exactly what cmake -D switches, paths
> and sources I need?
> I've cloned github.com/apache/arrow, and added it to my paths.
> Clearly, I'm missing something.
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
