[gdal-dev] Directories and Parquet
Scott public at postholer.com
Fri Jul 28 15:19:09 PDT 2023
For what it's worth, this is as far as I've gotten and it works:
ogr2ogr -dialect sqlite -sql @admins.sql -nln over -overwrite
admins.gpkg /vsis3/overturemaps-us-west-2/release/2023-07-26-alpha.0
I've got a cheat sheet set up with the sql at:
https://www.postholer.com/articles/Overature-Cheat-Sheet
On 7/28/23 15:14, Michael Smith wrote:
> Here's fetching the first admin boundary:
> docker run --rm -it ghcr.io/osgeo/gdal:ubuntu-full-latest ogrinfo /vsis3/overturemaps-us-west-2/release/2023-07-26-alpha.0/theme=admins/  -where "type='administrativeBoundary'" -al  -fid 1
> Warning 1: Field names of unhandled type map<string, list<array_element: map<string, string ('array_element')>> ('names')> ignored
> Warning 1: Field sources of unhandled type list<array_element: map<string, string ('array_element')>> ignored
> INFO: Open of `/vsis3/overturemaps-us-west-2/release/2023-07-26-alpha.0/theme=admins/'
>        using driver `Parquet' successful.
> Layer name: theme=admins
> Geometry: Unknown (any)
> Feature Count: 96455
> Extent: (-180.000000, -89.999900) - (180.000000, 89.999900)
> Layer SRS WKT:
> (unknown)
> Geometry Column = geometry
> updatetime: String (0.0)
> version: Integer (0.0)
> adminlevel: Integer (0.0)
> maritime: String (0.0)
> subtype: String (0.0)
> localitytype: String (0.0)
> context: String (0.0)
> isocountrycodealpha2: String (0.0)
> isosubcountrycode: String (0.0)
> defaultlanugage: String (0.0)
> drivingside: String (0.0)
> bbox.minx: Real (0.0)
> bbox.maxx: Real (0.0)
> bbox.miny: Real (0.0)
> bbox.maxy: Real (0.0)
> type: String (0.0)
> OGRFeature(theme=admins):1
>    id (String) = 85186a93fffffff1100000000000007
>    updatetime (String) = 2023-05-28T00:18:08.062Z
>    version (Integer) = 0
>    adminlevel (Integer) = 4
>    maritime (String) = (null)
>    subtype (String) = (null)
>    localitytype (String) = (null)
>    context (String) = (null)
>    isocountrycodealpha2 (String) = (null)
>    isosubcountrycode (String) = (null)
>    defaultlanugage (String) = (null)
>    drivingside (String) = (null)
>    bbox.minx (Real) = -0.6814001
>    bbox.maxx (Real) = -0.6561592
>    bbox.miny (Real) = 46.686869
>    bbox.maxy (Real) = 46.7005651
>    type (String) = administrativeBoundary
>    LINESTRING (-0.6561592 46.7005651,-0.6576952 46.7001611,-0.6596517 46.6992552,-0.6607547 46.6986231,-0.661421 46.6981174,-0.6642916 46.6959388,-0.6664351 46.6949608,-0.6700295 46.6934809,-0.670524 46.6932773,-0.6719283 46.6922006,-0.6738641 46.6916239,-0.6749166 46.6910205,-0.6764343 46.6894853,-0.6767317 46.6893071,-0.6784728 46.688264,-0.6797574 46.6881753,-0.6807998 46.6873219,-0.6811768 46.6870573,-0.6814001 46.686869)
> Mike
> On 7/28/23, 6:05 PM, "Michael Smith" <michael.smith.erdc at gmail.com <mailto:michael.smith.erdc at gmail.com>> wrote:
> Paul,
> I had to use 3.7.1 to have it read the geometry properly, 3.7.0 would read the directories.
> docker run --rm -it ghcr.io/osgeo/gdal:ubuntu-full-latest ogrinfo /vsis3/overturemaps-us-west-2/release/2023-07-26-alpha.0/theme=admins -al -so
> INFO: Open of `/vsis3/overturemaps-us-west-2/release/2023-07-26-alpha.0/theme=admins'
> Feature Count: 99403
> Layer SRS WKT:
> (unknown)
> type: String (0.0)
> Mike
