[gdal-dev] ogr2ogr sqlite dialect and fgb format
    Patrick Young
    patrick.mckendree.young at gmail.com
    Wed Jun 28 08:18:41 PDT 2023
I'm playing around with the gdb dataset
https://data.cityofnewyork.us/Transportation/NYC-Planimetrics/wt4d-p43d
and getting errors starting with gdal 3.5 when I try to use the sqlite
dialect:
ogr2ogr -f GeoJSONSeq -sql "select shape from roadbed where source_id =
13350003311" -dialect sqlite /vsistdout/
NYC_DoITT_Planimetric_OpenData.gdb.zip
ERROR 6: Unsupported field type for range domain: esriFieldTypeDate
ERROR 1: Cannot create virtual table for layer 'roadbed' : CREATE VIRTUAL:
invalid SQL statement : CREATE TABLE "roadbed"("SOURCE_ID"
FLOAT,"FEATURE_CODE"
INTEGER_INT16_BEGIN_DOMAIN_NAME_64526F6164626564_END_DOMAIN_NAME,"SUB_FEATURE_CODE"
INTEGER,"STATUS"
VARCHAR(16)_BEGIN_DOMAIN_NAME_645374617475735F31_END_DOMAIN_NAME,"SHAPE_Length"
FLOAT,"SHAPE_Area" FLOAT,OGR_STYLE VARCHAR HIDDEN,"SHAPE"
BLOB_MULTIPOLYGON_XY_2263, OGR_NATIVE_DATA VARCHAR, OGR_NATIVE_MEDIA_TYPE
VARCHAR)
ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(select shape from roadbed
where source_id = 13350003311):
  no such table: roadbed
This command works in GDAL 3.4 (and also works with the ogr sql dialect); I
was wanting to use the sqlite dialect so that i can use CASE statements.
Is this a bug or expected?
Thanks,
Patrick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230628/b6d91724/attachment.htm>
