[gdal-dev] GDAL - Python Bindings - CURL NETRC_FILE
Morgan Kerle morgankerle at gmail.com
Sun Mar 12 08:41:01 PDT 2023
Ok, thank you very much for your time and assistance Even.
Morgan
On Sun, 12 Mar 2023 at 11:35, Even Rouault <even.rouault at spatialys.com>
wrote:
> You're right, I looked too fast. I've added a GDAL_HTTP_NETRC_FILE option
> in https://github.com/OSGeo/gdal/pull/7435
> Le 12/03/2023 à 16:11, Morgan Kerle a écrit :
> HI Even,
> Thanks for your reply. I had assume that GDAL_HTTP_NETRC set the option
> NETRC as in papszOptions which accepts "YES" or "NO" to indicate if
> ~/.netrc file or $NETRC should be searched for credentials. If this is the
> same option as CURLOPT_NETRC (https://curl.se/libcurl/c/CURLOPT_NETRC.html),
> then it does not allow the user to specify a location for the .netrc file.
> In any case, I attempted setting the GDAL_HTTP_NETRC via
> gdal.SetConfigOption(), but I am still getting the same curl output
> (Couldn't find host data.lpdaac.earthdatacloud.nasa.gov in the (nil)
> file; using defaults).
> I assume (nil) file should be showing the file path supplied via
> GDAL_HTTP_NETRC?
> Morgan
> On Sun, 12 Mar 2023 at 10:58, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Morgan,
>> The right name is GDAL_HTTP_NETRC :
>> https://gdal.org/api/cpl.html#_CPPv412CPLHTTPFetchPKc12CSLConstList
>> Even
>> GDAL_HTTP_NETRC
>> Le 12/03/2023 à 15:49, Morgan Kerle a écrit :
>> I am trying to use the /vsicurl/ file hander to access a remote tiff file
>> using basic auth. Is it possible to provide a alternate location
>> for a .netrc file via the Python bindings? I have attempted to use
>> SetConfigOption("CPL_CURL_NETRC_FILE" "abs/file/path/to/.netrc").
>> This appears to correctly set the CURL_NETRC_FILE option, as CURL
>> debugging output shows "Couldn't find host
>> data.lpdaac.earthdatacloud.nasa.gov in the (nil) file; using defaults".
>> However, it appears the file is not found / accessible by libcurl.
>> Any suggestions as to why this may be the case? I have already confirmed
>> that the file exists and is accessible, and running CURL with the same
>> parameters in bash works fine.
>> Regards,
>> Morgan
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230312/f16c2054/attachment-0001.htm>
