[gdal-dev] GDAL 3.7.0 release candidate available
Even Rouault even.rouault at spatialys.com
Tue May 2 11:14:52 PDT 2023
Holger,
thanks for the feedback. Fixed per
https://github.com/OSGeo/gdal/commit/b0039c648073713578bb0360f92a6c859a011832
and backport to the 3.7 branch
I will probably not issue a new RC just because of that as those files
aren't used by the code, so this will probably be only in 3.7.1
Even
Le 02/05/2023 à 19:57, Holger Jaekel a écrit :
> Even,
> Am 02.05.23 um 16:03 schrieb Even Rouault:
>> I have prepared a GDAL/OGR 3.7.0 release candidate.
> The release candidate builds well on Alpine Linux Edge. I just observed
> that the files gfs.xsd and gml_registry.xsd were mentioned in the news
> but not copied to /usr/share/lib/gdal
> Also the filename is ogrinfo_output.schema.json and not
> ogrinfo_output.json.schema as it says in the news.
> Best
>   Holger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
